Installing remix os
Hey y'all. So I purchased a preloaded sd card with Android. It works just fine, but after seeing a friend use remix os, I've decided to switch.
On this wiki page there what look to be a bunch of images I can burn to using dd on linux. Last I had looked we have to use this phoenix tool on windows.
Am I able to use these dd images safely?
(07-07-2016, 11:57 AM)fooclueshoedo Wrote: Hey y'all. So I purchased a preloaded sd card with Android. It works just fine, but after seeing a friend use remix os, I've decided to switch.
Prior to the dd img, you had to use Phoenix... since the dd img that is old information (I think) you can use dd img from gnu+linux safely...
best
marcus
It is indeed old information, dd images provide another option for burning OS images for those that can't/don't want to use the PhoenixCard software.
Thank you both for the information. For anyone looking...
It took about 3 hours to copy over to my 64gb sd card, but I successfully installed it and have remix os running.
I ran this to find the device for the sd card.
sudo fdisk -l
 It happened to be '/dev/mmcblk0'
Then I ran this...3 hours later it was good to go.
sudo dd if=/home/fooclueshoedo/Downloads/remix-v2.0-20160415-pine64-64GB.img of=/dev/mmcblk0
Question Issue installing New OS Using SD Rudy558 2 6,419 06-29-2021, 03:37 AM
Last Post: TfromTexas
Information Installing Node.js from source on Arch Linux faddah 1 13,085 09-15-2017, 06:45 AM
Last Post: carlonsins
  remix os Phoenix CARD and Win32 Problem pilgrimage 4 11,262 08-17-2016, 02:30 AM
Last Post: pfeerick
  Pine Arrived; No Sound in Remix Using HDMI Bob123456789 2 7,286 07-06-2016, 02:02 PM
Last Post: Bob123456789
  <Noob - My experience setting up Remix OS BeerSnob 3 9,625 06-15-2016, 09:22 AM
Last Post: BeerSnob
  [REQUEST] Youtube video tutorial for dual-install Ubuntu + Remix OS 7777777 14 31,016 03-30-2016, 09:32 AM
Last Post: montyflange
