Overclocking available?
Pink liquid cooling is an absolute must! Haha. But not something I'll be pursuing
(01-28-2016, 03:55 PM)tllim Wrote:
(01-28-2016, 01:53 PM)frodo_loves_metal Wrote:
(01-28-2016, 01:20 PM)pine.tree Wrote: I measured the laptop fan, it is just under 20mm square. Does anyone know how tall the acrylic enclosure is? I might also put some fans on the side, totally out of the way of the board. I think there's a bit of room to all edges of the board, I could fit some fans in the outer perimeter of the case.
I will also be cautious about overclocking, I'd at least like to get it up to 1.5Ghz if I can.
Not sure about the dimensions of the acrylic case --- there was backlash on the Kickstarter page earlier this week when they posted an update that had a picture of the new (much less attractive) AVAA Studios case.
It might be tough planning for components when you don't know the exact clearance. Even if you study the pictures and calculate every dimension (like I have done in the past...), there's inevitably some little issue that can mess with your meticulous planning. That's why I'll wait until I have the hardware in my hands before I plan for components. Just my two cents!
You could also go this route: http://hackaday.com/2013/07/20/water-coo...pberry-pi/
The sandwich type acrylic case has around 20-22mm clearance (assume not install adapter on top), this should have enough clearance for ma good heatsink. The case height between two acrylic plate is 40mm.
P/S: I don't think water cool is needed :-)
Thanks for the dimensions, now all i've got to do is wait until March Tongue
If I've helped you with something, please leave a rating for my responses.
(01-28-2016, 12:44 PM)frodo_loves_metal Wrote:
(01-28-2016, 07:28 AM)pine.tree Wrote:
(01-28-2016, 07:11 AM)taros Wrote: The dimensions of the A64 (the SoC) are 15mm x 15mm. There is enough clearance for up to about 20mm x 20mm.
The dimensions of the voltage regulator are 9mm x 9mm.
You can buy 15mm x 15mm heatsinks for cheap. Some come with adhesive tape.
See http://www.michaeldornisch.com/2012/06/d...-sink.html on how to may your own tiny heatsinks.
Requires tools to cut a bigger heatsink to smaller ones.
They got a reduction in temperature of about 18C.
Thanks! I have this old laptop with a small fan, i think i'll be doing the DIY way.
That would need to be a teeny tiny laptop fan!
I plan on overclocking and cooling, but certainly below 2GHz. I doubt the OS is stable at 2GHz even if the CPU is properly cooled. I'll wait until I get my P64+ in March and then start tinkering. I'll start with a small inexpensive heatsink and see how I do. Something like this should work: http://amzn.com/B00HPQGTI4. I'm hoping a heatsink plus the four-post open air case gives the unit enough breathing room for some mild overclocking.
Already have my heatsinks, and all my other stuff, . . just waiting for my board now
Backer number: 24,762
Backerkit STATUS: Items Received
  Overclocking coleshores 24 49,619 10-28-2016, 03:25 AM
Last Post: pfeerick
