Pass-through
Thumbs Down
Please find a solution to the pass-through problem....!
I got the Pine64 for using Android environment with Kodi
Angry
Sent from my A0001 using Tapatalk
any updates?!?!?!
hi Moshe,
I noticed your cross-post (one is enough). What is your setup... what do you mean by pass-through?
Do you get audio and video with kodi? (without passthrough, whatever that means)
marcus
In order to use the AVR audio processor I need to enable the pass through in kodi.
Setup is simple connecting the HDMI output from the pine to the HDMI input in my AVR.
... for my notes, is this issue a Droid problem, or a Kodi problem ?
does it look like kodi is being configured (just doesnt work) or is the configuration missing ?
marcus
PS what happens instead... just no audio ?
It is the allwinner board issue... But it can be solved with software ... When I enable the pass through the audio skips every 1-3 seconds... You cannot use it like that... In my raspberry pi this issue is not happening
I see your point. I would like to see it also enabled in future. Update or Marshmallow is on the way so use it and try it, if it doesnt work just ping TLLim.
For Kodi you should buy Odroid C2
hi Moshe,
One of my homies on the irc.pine64.xyz:6697 chat suggested following this guide:
http://www.zidoo.tv/Support/guide/id/2/p/1.html
... it is very specific; but, maybe you have already tried this and you still have the skip issue ?
marcus
Thanks this is exactly the steps that I took ... Not solving the problem... Sad
