Sent from my A0001 using Tapatalk
hi Moshe,
I noticed your cross-post (one is enough). What is your setup... what do you mean by pass-through?
Do you get audio and video with kodi? (without passthrough, whatever that means)
marcus
In order to use the AVR audio processor I need to enable the pass through in kodi.
Setup is simple connecting the HDMI output from the pine to the HDMI input in my AVR.
07-06-2016, 10:06 AM
(This post was last modified: 07-06-2016, 10:07 AM by MarkHaysHarris777.)
... for my notes, is this issue a Droid problem, or a Kodi problem ?
does it look like kodi is being configured (just doesnt work) or is the configuration missing ?
marcus
PS what happens instead... just no audio ?
It is the allwinner board issue... But it can be solved with software ... When I enable the pass through the audio skips every 1-3 seconds... You cannot use it like that... In my raspberry pi this issue is not happening
07-06-2016, 10:56 AM
(This post was last modified: 07-06-2016, 10:57 AM by Pepe.)
I see your point. I would like to see it also enabled in future. Update or Marshmallow is on the way so use it and try it, if it doesnt work just ping TLLim.
For Kodi you should buy Odroid C2
