Remix OS Screen Size problem
Hi guys,
I'm trying to run Remix OS via an HDMI on my HDTV. For some reason, the picture ends up being too large and the corners end up running off the side of my TV. I can't find anywhere within the OS that lets you adjust the screen resolution or a way to adjust the screen size.
Has anyone else had this issue?
Thanks,
Sean
Go through your TV settings (submenus too) and see if you can set the resolution to 1080p60 or 720p60.
Here's a little more detail to add to Mark's suggestion: http://forum.pine64.org/showthread.php?tid=1401
As for options in the OS, Remix OS apparently doesn't have the option available in the Method 2 section for Android.
  sourround sound - Remix MrSarkasmus 0 5,089 10-05-2018, 05:05 AM
Last Post: MrSarkasmus
Star Remix OS 2.0 Image Release 20160718 tllim 25 63,415 08-30-2018, 01:21 PM
Last Post: Idemdesign
  Remix os os 64bits ?? Matroxplay 1 6,942 07-14-2018, 11:48 AM
  Remix OS NMancuso 111 248,408 08-01-2017, 03:51 AM
Last Post: wappi
Question Nginx proxy on Remix OS -- possible? mitchmitchell 1 7,480 05-29-2017, 02:45 AM
Question Remix OS 2.0 [20170105] Waaaa??? veronicasmithen03 1 7,275 05-29-2017, 02:42 AM
  REMix OS Boots and then blank Screen Michaelrowe01 6 25,422 04-17-2017, 04:20 AM
Last Post: simplexdan
  Stuck at Remix OS logo leongzhi 9 33,573 12-21-2016, 08:09 AM
Last Post: Michaelrowe01
Exclamation LCD TOUCH SCREEN PANEL support in Remix? mcfly777 4 13,314 12-19-2016, 07:49 PM
Last Post: Toriless
  Guest Account in Remix OS cannot Get Internet Connection deniyulianti 1 6,576 10-15-2016, 07:16 AM
Last Post: MarkHaysHarris777
