Driver usb wifi dongle 8192eu
Question
Can the kernel be bumped to a version that supports the driver for usb wifi dongle 8192eu?
I just looked and my kernel has a rtl8192cu driver...
did you run pine64_update_kernel.sh ?
My kernel version is:
ubuntu@pine64:/$ uname -a
Linux pine64 3.10.102-0-pine64-longsleep #7 SMP PREEMPT Fri Jun 17 21:30:48 CEST 2016 aarch64 aarch64 aarch64 GNU/Linux
ubuntu@pine64:/$ lsmod
Module Size Used by
rtl8192cu 66504 0
rtlwifi 60032 1 rtl8192cu
rtl8192c_common 40280 1 rtl8192cu
mac80211 370652 2 rtlwifi,rtl8192cu
Yes, I ran the update scripts and have the same driver. This device really needs the eu, not the cu, driver. Not sure in which exact kernel version this got supported a while back, but that is the only way to solve this in a robust way.
I have reported it at https://www.pine64.pro/bug-reports-3-10-65-bsp/ under the title "Support USB WiFi dongle driver 8192eu" but could not link to it directly. Perhaps someone else can post a direct link to it.
Did you try 'sudo apt-get update' then 'sudo apt-get install linux-firmware' ? That worked for me, and I've had 5 different usb wifi adapters work seamlessly on my Pine64 with Debian Mate.
(06-30-2016, 10:11 AM)CaptainZalo Wrote: Did you try 'sudo apt-get update' then 'sudo apt-get install linux-firmware' ? That worked for me, and I've had 5 different usb wifi adapters work seamlessly on my Pine64 with Debian Mate.
Could you possibly list them? I'm having problem with my wifi adapter and I would consider buying new one if there is one inexpensive that works for sure.
if this is debian the realtek firmware should be already there if it is ubuntu firmware-linux-nonfree firmware-realtek are more than likely your best bet
try apt-cache search firmware to search for all firmware packages (realtek should be listed there as well as linux-nonfree)
If you like my work be sure to check out my site or wish to donate to the cause
Cheers Big Grin
Hi CaptainZalo,
 Please list the 5 models of usb wifi adapters that work for you on the Pine64.
I'm pretty sure that this would benefit others as well.
Thanks  Smile
btw I have a Prolink usb wifi dongle that should be compatible. I've yet to test it out since I need to obtain a switch that I can solder onto the board.
When that's done, I will install debian and test out the dongle. Its supposedly linux & android compatible.
Hi CaptainZalo,
Thanks  Smile
Sorry. I haven't subscribed to this thread, so I didn't see this post until vinod made me aware of it. Here is what I wrote him in a PM:
I am currently on summer vacation and won't get back home until last half of august. I can remember this:
1: NetGear N300 Mini USB, unknown chipse. Realtek I think.
2: WiPi old adapter with BCM43143 chipset.
3: New WiPi adapter (red text and slanted edge) with Ralink 5370 chipset.
4: A NoName adapter with RealTek RTL8192 chipset.
5: Last one is a nano style USB linksys adapter, but I can't remember name or chipset.
All of these work in ubuntu and debian images after doing 'sudo apt-get install linux-firmware'
  WiFi dongle MediaTek mt7601u Beta_Ravener 13 37,108 11-28-2017, 11:58 AM
Last Post: Aadhyatm
  Pre-Configure Wifi on Pine64 without Keyboard/mouse bortek 4 11,969 01-23-2017, 02:04 PM
Last Post: bortek
  Mali driver for fbdev/kms & wayland? jacklau 1 6,179 10-21-2016, 11:19 AM
Last Post: CaptainZalo
  Pine64+Ubuntu+Tvheadend+DVBT Dongle Shai 3 10,732 10-03-2016, 04:23 AM
Last Post: Shai
  WiFi PineA64 Pineapple Ghelorn 2 9,893 09-25-2016, 03:05 AM
Last Post: Ghelorn
Question Mali Driver Update FR0$T 2 7,589 07-20-2016, 10:44 AM
Last Post: nagmier
  third party wifi rahlquist 3 8,609 04-27-2016, 02:39 PM
Last Post: baryluk
