No CIFS support in Kernel?
mount error: cifs filesystem not supported by the system
mount error(19): No such device
[root@alarm autofs]# modprobe cifs
modprobe: FATAL: Module cifs not found in directory /lib/modules/3.10.65-4-pine64-longsleep
Did you tried to install it using "apt-get install cifs-utils" ?
Your Kernel is outdated - See http://forum.pine64.org/showthread.php?tid=293 for when cifs support has been added an for update instructions.
as longsleep stated.
Simply execute the following
sudo -i
resize_rootfs.sh
reboot
on next boot
sudo -i
pine64_update_uboot.sh
pine64_update_kernel.sh
reboot
tada you are now up to with the the kernel/uboot/and using up the full extent of your sd card Wink
If you like my work be sure to check out my site or wish to donate to the cause
Cheers Big Grin
thanks guys!
  eMMC doesn't work after kernel start m.bakhterev 3 10,849 10-15-2019, 10:58 AM
Last Post: m.bakhterev
  Arch Linux image (BSP Kernel) longsleep 28 102,298 05-06-2016, 06:33 PM
