DC Power IN Power-ON Switch Reset Switch -- Batt Required
I have a couple of tips regarding the DC IN Power-ON & Reset switches. First off, they are right-angle switches which have a beefy frame (say heatsink) and therefore require a 40 watt iron to solder in (your little 15 or 25 watt iron isn't going to cut it).
Secondly, and maybe most importantly, the power-on switch is not going to work without the DC batt plugged in and fully charged. The PMIC detects that the batt isn't there and immediately shuts down the system; this is why several of you are reporting that your switch isn't working. The reset does just that (a reset) not a good thing to do without a clean shutdown first. Holding the power-on button for a while will do a hard power-off if that were required (like any notebook computer, &c). Otherwise, the power-on button sends a keycode to the kernel (I have not been able to verify but I think its 116; let you know). This could be trapped to signal a clean poweroff. With a fully charged batt plugged in the power-on button will power-up the device without removing the main power plug. Not sure if a small backup battery would be enough; will have to test.
marcus
PS ... click the thumbnail above to get a larger view/
You can test if your powerbutton sends a keycode with evtest, the driver basically registers the button like another keyboard:
ubuntu@pine64:~$ sudo apt-get install evtest
Reading package lists... Done
Building dependency tree
Reading state information... Done
evtest is already the newest version (1:1.33-1).
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
ubuntu@pine64:~$ sudo evtest
No device specified, trying to scan all of /dev/input/event*
Available devices:
/dev/input/event0:      sunxi-keyboard
/dev/input/event1:      axp81x-supplyer
/dev/input/event2:      sunxi-ths
/dev/input/event3:      audiocodec sunxi Audio Jack
/dev/input/event4:      sunxi_ir_recv
/dev/input/event5:      MCE IR Keyboard/Mouse (sunxi-rc-recv)
Select the device event number [0-5]: 1
Input driver version is 1.0.1
Input device ID: bus 0x19 vendor 0x1 product 0x1 version 0x100
Input device name: "axp81x-supplyer"
Supported events:
 Event type 0 (EV_SYN)
 Event type 1 (EV_KEY)
   Event code 116 (KEY_POWER)
 Event type 2 (EV_REL)
Properties:
Testing ... (interrupt to exit)
Event: time 1466799328.888825, type 1 (EV_KEY), code 116 (KEY_POWER), value 1
Event: time 1466799328.888825, -------------- SYN_REPORT ------------
Event: time 1466799328.999256, type 1 (EV_KEY), code 116 (KEY_POWER), value 0
Event: time 1466799328.999256, -------------- SYN_REPORT ------------
Event: time 1466799329.630542, type 1 (EV_KEY), code 116 (KEY_POWER), value 1
Event: time 1466799329.630542, -------------- SYN_REPORT ------------
Event: time 1466799329.798206, type 1 (EV_KEY), code 116 (KEY_POWER), value 0
Event: time 1466799329.798206, -------------- SYN_REPORT ------------
ubuntu@pine64:~$
(06-24-2016, 02:15 PM)xalius Wrote: You can test if your powerbutton sends a keycode with evtest, the driver basically registers the button like another keyboard:
Thank you, xalius !
... yes, the keycode is in fact 116; and it works great-- I've only tested it on the xenial ubuntu image, signals a shutdown just like clicking 'shutdown'... 59 seconds later down we go; of course, that may be canceled too.
So, now I need a 3.7v backup batt to check the power-on /
marcus
Yeah I want to play with the battery charger too, but Tl Lim needs to find some time to translate the datasheet of the one they sell in the shop so I can get something similar. Just dont make it too small since the default charge current is quite high if I remember correctly...
(06-24-2016, 02:42 PM)xalius Wrote: Yeah I want to play with the battery charger too, but Tl Lim needs to find some time to translate the datasheet of the one they sell in the shop so I can get something similar. Just dont make it too small since the default charge current is quite high if I remember correctly...
Thanks, this is good to know-- I have a little small batt from my Intel Edison, which I won't be plugging after all... I'll wait till I have the official one !
Tnx
Grüß
Available devices:
Supported events:
Properties:
ubuntu@pine64:~$
Thanks for that! Now I know my button is working! Smile
So, next my next question is : Do you know any (simple!) way to get the pine64 to respond to it? I'm using debian, and would like to make it trigger a shutdown. I keeps seeing mention of xbindkeys seeming to be able to do this, but I want a headless machine to be able to do this, not one with X11.
Edit: So, after a little more digging, and coming across a wiki page about udev and sleep buttons, I sort of followed the instructions and ended up with this for a udev rule, and it works!
pfeerick@pine64:~$ more /etc/udev/rules.d/70-power-switch-my.rules
ACTION=="remove", GOTO="power_switch_my_end"
SUBSYSTEM=="input", KERNEL=="event1", ATTRS{name}=="axp81x-supplyer", TAG+="power-switch"
LABEL="power_switch_my_end"
I then executed the following commands to freshen things up, and voila... pressing the power button causes the pine64 to instantly start shutting down! Now to see if I can make it trigger a delayed shutdown - say with 1 minutes grace...  Smile
sudo systemctl restart systemd-udevd
sudo udevadm trigger
sudo systemctl restart systemd-logind
As a side-note, connecting the battery can be annoying - when the battery is connected, when I tell the pine64 to poweroff / halt, it powers itself back up again.
Nice one on the use of udev ... I used the package trigger-happy which can monitor multiple input devices at once and is also useful to bind the buttons of the IR remote to commands... as for the Pine turning back on with the battery connected... I think we need to check on the PMIC driver there....
  Which Power Supply Unit for Pine64 A64 DB V1.1 2GB REV B (year 2016)? databaseprogrammer 1 7,242 07-03-2021, 01:29 AM
Lightbulb Alternate Power DC-IN on the Euler Bus also with PI filter for batt operation MarkHaysHarris777 13 37,832 12-19-2020, 09:53 PM
Last Post: evilpete
  Once Again: Power Supply problems I guess (Pine A64+ locking up) marcelser 0 5,428 06-04-2018, 03:11 PM
Last Post: marcelser
  Power supply problems. larsen8989 5 15,216 05-03-2018, 09:01 PM
  solar power on a Pine64 tablet Little_Johnny 11 28,473 03-20-2018, 12:01 AM
Last Post: pfeerick
  Power up HDDs c4tich 3 10,787 03-18-2017, 09:18 AM
Last Post: Luke
  Provide power in via Pi-2 header BenCranston 22 51,600 03-08-2017, 10:38 PM
Last Post: pfeerick
  any danger from using 2 power sources at same time? dkryder 3 11,476 01-20-2017, 10:45 PM
Last Post: MarkHaysHarris777
Lightbulb A Tale of Two Power Supplies - why good is good and better is best MarkHaysHarris777 9 28,866 01-07-2017, 11:59 PM
Last Post: aegrotatio
  First cable for Euler Bus power done! AVL2016 24 56,202 10-05-2016, 06:43 AM
Last Post: Ghost
