1 hour ago
I'm planning a small home sensor setup in Madison and I'm comparing single board computer options. The Raspberry Pi 3 Model B+ keeps coming up in what I've read online, and I've seen a 1GB version mentioned alongside it. My concern is the memory: for a handful of sensors and a lightweight web dashboard, is 1GB enough, or will it start swapping once I add logging? I also wonder about power and heat in a small enclosure, since this would sit in a closet. I don't need video or heavy compute, just reliable uptime. Since many of you here work with PINE64 boards, how do the specs and community support compare for a beginner? I'd rather avoid buying twice. If you've run a similar project, what would you check before deciding?
