Systemupgrade fails
I have perform a system upgrade/actualization and it fails. It looks like all is working fine but after restart it ends in a endless loop. Enter the GUI is no longer possible.
With CTRL+ALT+F2 I can enter the Terminal. My account is working but no network and "startx" fails.
I have try to install the available actualization in discovery and later, after a "factory reset", in terminal "sudo pacman -Syu". All the same.
After the actualization e.g. freecad, musescore are working (before only installing possible) but after a restart... next "factory reset".
Any ideas?
Have give it a try this morning. looks like all is working fine.
sudo pacman -Syu
Is working without error. Restart was working now and any software I need (FreeCAD, Musescore, Libreoffice,...) is also working now.
Very nice.
Thanks a lot.
