Second screen mirroring
hello I would like to know if I can connect pinenote with starlite tablet via usb cable and hdmi adapter?
I want to too. Please check my inbox
Connecting PineNote to a Starlite tablet via a USB cable and HDMI adapter is not a common and feasible method. PineNote uses an e-ink screen, which is not compatible with HDMI signals, and most Android tablets (like Starlite) do not support HDMI input. If you want to share data between the two devices, you can try Connect via Bluetooth or Wi-Fi instead of using a USB or HDMI cable.
[color=oklab(0.952331 0.000418991 -0.00125992)]You cannot directly connect a PineNote to a StarLite tablet via a USB cable and HDMI adapter for video output from the PineNote. The StarLite tablet has a Micro HDMI port and its USB-C ports support DisplayPort Alt Mode for outputting video to an external monitor. While it might be possible to use the StarLite as an external display through software workarounds like VNC, it's not a standard plug-and-play input via its USB-C or HDMI ports. The PineNote's USB-C port is USB 2.0 and does not support DisplayPort output. This means it cannot send a video signal through a USB-C to HDMI adapter. [/color]fnaf
[color=oklab(0.952331 0.000418991 -0.00125992)]So, while the StarLite tablet can display video from itself, and has an HDMI input, the PineNote lacks the necessary video output capability from its USB-C port to send a display signal to the StarLite.[/color]
  PinePower 120W Screen Issues t-3 3 5,409 09-26-2022, 05:14 PM
Last Post: superkamiguru
  onscreen keyboard, screen locker and other tools(X) moved ! jack1 0 2,548 08-10-2021, 03:19 PM
Last Post: jack1
  Mirroring Pine64 software phasewrap 2 6,101 05-17-2021, 02:29 PM
Last Post: robinjamess
  smlock minimal screen locker jack1 0 3,153 11-28-2020, 05:03 PM
Last Post: jack1
  touch screen panel question diggledorf 1 5,104 08-23-2020, 06:09 PM
  Stuck on login screen Kscott6969 2 6,659 04-21-2020, 06:14 PM
Last Post: Dendrocalamus64
  Pine64 lcd touche screen Rigor_M 0 3,821 09-18-2017, 10:15 AM
Last Post: Rigor_M
