Isn't there a...
Naked installer for Pinephone Pro, where after the base is installed I can just choose to install a gui through terminal.
I could've sworn I seen one or barebones or base on github once, now I can't find it.
Reason why is I typically install go with Mobian and then install Plasma over it, but I've got dupelicates of stuff, settings, stores, etc and tinkering around trying to remove the phosh stuff tends to typically make it fall apart and bork the rest of the way.
(11-23-2024, 06:55 AM)dorkydev Wrote: Naked installer for Pinephone Pro, where after the base is installed I can just choose to install a gui through terminal.
 you mean barebone arch ?
  https://wiki.pine64.org/index.php?title=...e_Releases
 ezik
 ezik
Yes I found it, what's the proper terminal command to install plasma in it, I tried the basics and they didn't work.
I'd be interested too, and I don't even kow what would be >the basics<, but I am interested in plasma mobile. Is there a howto?
(11-23-2024, 09:45 PM)dorkydev Wrote: Yes I found it, what's the proper terminal command to install plasma in it, I tried the basics and they didn't work.
 if you want plasma why berabones ?
 ezik
