How can I get the permissions to write to the external SD card ...?
(10-19-2023, 11:04 AM)walter1950 Wrote:
(10-19-2023, 12:23 AM)Peter Gamma Wrote: Thanks walter1950 for sharing this
- The fact that LibreOffice is highly costumizable for instance for the Pinephone:
https://forum.pine64.org/showthread.php?...614&page=5
- has encouraged me to make another tests. Who wants to be debugger of an app like Abiword, an app for which developement has basically stopped then years ago?
- So I still have LibreOffice to test if Abiword fails and can avoid going completely crazy looking for a wordprocessor for the Pinephone which works for my use case if Abiword should not work.
- Wordprocessor, text editor, I am not an expert in this field, and I do not know the exact definitions of these terms. So let's stick with Abiword and LibreOffice Writer.
- I did another test and created with Abiword a file and save it in the .odt format on an Ubuntu PC
- This is also the format in wich LibreOffice saves files.
- I created another file with LibreOffice Writer in the .odt format on my Ubuntu PC.
- I stored both of these files to an SD card.
- Then I was able to open the file I have created with Abiword in the .odt format on my Pinephone with Abiwrod and had not the issues I described above.
- Also the LibreOffice Writer file I created on my Ubuntu PC which i stored on an SD card and opened it with LibreOffice Writer on my Pinephone was perfect.
- But I think it needs further testing especially the issues I experienced with Abiword files I created on the Pinephone, then edited on my Ubuntu PC, which had issues when I opened those files again on the Pinephone.
- it remains to be seen if the issues I described above can be solved by choosing the .odt formatl
Pinephone Original
Mobian Trixie (UpToDate)
Ok, I have einstalled ABIWORD on Pinephone, wrote some Letters and saved it to SD-Card.
The SD-Card inserted in PC (Ubuntu 20.04) and doubleclicked this *.abw-File from SD-Card.
"LibreOffice Writer" opens the File and I wrote some more Text there.
LibreOffice is saving this *abw-File to *.odt. There are no "Export-Function" to save/convert it as *.abw.
SD-Card back to Phinephone and Abiword opens the *.odt-File nicely.
What I have written, with LibreOfice to this File, is still there.
BTW:
LibreOffice is the Way to go :-)
HTH
Ciao
Walter
- I am revisting a problem which I tried to solve last year.
- Thanks for the answer, Walter1950, your procedure sounds very interesting.
- I only saw it now and are looking more closely at it.
- I have put my Pinephone on the screed last year when I had no time to look at this problem more closely.
- Now when I started my Pinephone I did not remember my password for postmarketOS
- So I have to admit I have not tested  Walter1950 s solution to this date.
- But I will do it as soon as I am able to login to my Pinephone again.
- So the following is a more theoretical solution I thought about.
- And I ask the question in another tread.
https://forum.pine64.org/showthread.php?tid=19297
  How to create a file on the SD card I can modify on my Ubuntu PC? Peter Gamma 0 2,767 06-16-2024, 02:33 PM
Last Post: Peter Gamma
  How to write the the external SD card with Abword? Peter Gamma 0 3,194 08-27-2023, 01:10 AM
  How can I open an Abiword file from an external SD card with Abiword? Peter Gamma 5 8,325 08-25-2023, 02:05 AM
  Help how to mount SD-Card chadwick 8 20,117 11-30-2021, 11:12 PM
Last Post: chadwick
  PP boots into factory test even if flashed sd card is inserted hapster 5 11,483 04-13-2020, 02:34 PM
Last Post: MartijnBraam
  terminal command for sd card size pnphn 5 12,112 04-02-2020, 12:51 PM
Last Post: someGermanGuy
