Screen ghosting and omitting rows of pixels...
Tongue
I've had my phone for over a year and several months ago it started omitting every 4th or 5th row of pixels, all down the screen. This makes text look unsmooth and as if it was made of lines. It also does a strange ghosting type thing where it continues to display blocks of the last pixels displayed. It's much more noticeable on black areas of the screen.
Currently, I'm running Arch Linux on it (phosh), but it's the same with Debian phosh and Debian plasma-mobile and some other OS I've tried.
The bizarre thing is that it seems to be perfect at times, but will then all the sudden start ghosting and omitting rows of pixels. This often happens during boot up. Once it happens, it tends to not go away.
I will say that I have used the phone in my bath though have never gotten water on it, but it has been exposed to humidity, so maybe that's it? Never had a problem with any of my other devices doing this. Right now I've put it infront of a heater to see if just maybe there was some residual water in it that could be evaporated.
Otherwise, the phone is perfectly fine; touch works perfectly, it's just as fast (or slow :p ), and I can take calls...
I'll send a picture of it in a week or so, as I've finally caved and bought an Android phone so will have a decent camera.
Also, I've not done any tweaks to it, such as over-driving the CPU or whatnot.
Any ideas or similar experiences?
  Screen dying already? marcih 156 311,589 06-12-2025, 06:18 AM
Last Post: mikeb
  Screen Replacement Instructions erikkugel 5 12,496 02-24-2025, 06:55 AM
Last Post: anonymous
  Replacement screen disconnects after back frame is screwed on robthebold 4 6,957 10-12-2023, 01:03 PM
Last Post: robthebold
  Severe screen flicker + occasional ghosting | Pinephone Beta edition legowave440 5 8,843 07-25-2022, 07:35 AM
Last Post: bedtime
  Double Image on screen Arvis 2 4,845 07-03-2022, 06:27 AM
Last Post: Avisando
  Screen has pixel-thin horizontal stripes that are black or get stuck in the past yasmi 5 9,434 03-08-2022, 12:25 PM
Last Post: jopple
  How hard to replace screen? Zebulon Walton 28 52,330 01-18-2022, 12:21 AM
Last Post: henrythemouse
  pinephone screen Uturn 2 5,386 01-14-2022, 01:15 AM
Last Post: Uturn
  Screen replacement Csanderson0313 4 7,560 01-10-2022, 09:26 PM
Last Post: Csanderson0313
  Top of screen and USB port malfunctioning Severinus 0 2,798 12-14-2021, 07:28 PM
Last Post: Severinus
