Rock64 is unreliable after 3 years of service - power problem?
Greetings all,
I have a Rock64 that I was using to self-host some services (namely Nextcloud).
It was powered on 24/7 for the best part of 3 years. It was connected by my router by ethernet. The only other connection was an external hard drive - the HDD had its own power supply so wouldn't have a high draw from the R64.
Around a year and a half into service, the USB 3.0 port that had the HDD connected stopped working. No matter, I just plugged it into one of the USB 2.0 ports and didn't experience any loss in performance.
Now it seems the whole unit is suffering from something. The ethernet connection shows on my router and I can ping the box, but as soon as I try SSH I am disconnected. I can begin a HTTP request but Apache fails with an internal server error message. When I power it on and view the console output on a monitor, I can login using a keyboard and nothing seems amiss in the OS (Armbian).
That said, if I connect anything to USB after the unit is powered on, it immediately reboots.
Something isn't right here. I suspect power related, but I'm not sure. These problems came all at once.
Would appreciate any help or suggestions.
Thanks, RTG.
there will be no peace when they release the geese
my homepage
I have experienced a similar problem with my 2 boards, except that they were lying unused for more than a year. The boards would not boot. I took out the SD cards and re-imaged the OS with a newer version of Debian. Both boards now boot but if I leave them OFF for a day or longer, they seem to suffer from brain damage i.e. they stop booting (even with the newer image of Debian)..
  DeskPi case alternative for ROCK64 v1k699 2 13,378 05-29-2025, 06:57 PM
Last Post: ameridroid
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 2 4,679 05-13-2025, 07:32 AM
Information How to Setup Serial Console Cable Over the Rock64 SBC MarkHaysHarris777 10 49,139 03-24-2025, 06:35 PM
Last Post: arunkhan
  Are HW design files available for ROCK64? irenek 3 11,464 12-11-2023, 09:31 PM
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 5,019 04-26-2023, 11:38 PM
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 21,890 01-15-2023, 10:36 AM
Last Post: ds00
  power connector type please AlexS 4 10,349 01-11-2023, 07:00 AM
Last Post: dmitrymyadzelets
  rock64 totally brick dakobg 2 6,711 11-07-2022, 05:45 PM
Last Post: olivercfc
  Alternative power supply ju0n 0 3,966 09-06-2022, 02:46 AM
Last Post: ju0n
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 9,062 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
