Ethernet regression on Linux Kernel 6.5.4?
Exclamation
Today I tried upgrading my board to the 6.5 series kernel and it seems eth0 no longer shows up.
the typical "rk_gmac-dwmac" dmesg entries don't show up at all.
Anyone else facing this issue? This is a headless system and debugging via UART isn't much fun, so I've booted back into the working 6.4 kernel.
Well, turns out a kernel option was renamed
-CONFIG_MFD_RK808=y
+CONFIG_MFD_RK8XX=y
Since it defaults to 'n' it got accidentally deselected and broke things. Built kernel with CONFIG_MFD_RK8XX and everything is fine again.
Thanks for posting the solution!
(09-21-2023, 02:16 PM)Deathcrow Wrote: Well, turns out a kernel option was renamed
-CONFIG_MFD_RK808=y
+CONFIG_MFD_RK8XX=y
FTR: You actually need MFD_RK8XX_I2C (which depends on MFD_RK8XX)
The split/rename was because there's now also a MFD_RK8XX_SPI (for rk3588). Previously there was only the I2C interface.
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 13 22,693 09-27-2026, 11:42 AM
  Freezes and kernel panics with Debian trixie jssfr 4 4,138 04-15-2026, 06:48 PM
Last Post: prahal
  Installing CH431SER on Ayufan 0.9.14: gitlab-ci-linux-build-159 Thisone 4 8,467 07-14-2023, 04:22 AM
Last Post: hunderteins
Question How do I compile an arbitrary kernel for U-Boot? Valenoern 3 6,993 06-16-2023, 10:54 AM
Last Post: CounterPillow
  Linux laptop does not detect the board when plugged in via USB soupy 1 7,899 04-13-2023, 03:01 AM
Last Post: Reynold Grady
  RockPro64 linux console video mode callegar 0 2,932 09-06-2022, 02:32 PM
Last Post: callegar
  [OS] SkiffOS and Buildroot for Rockpro64 w/ 5.17 kernel paralin1 1 4,584 05-08-2022, 03:26 PM
Last Post: paralin1
Brick Maintained Linux booting from eMMC ootoovak 10 18,402 04-30-2022, 03:57 PM
Last Post: TRS-80
  Kernel OOPs triggered by big writes to ext4 FS ajtravis 1 4,397 04-04-2022, 05:29 PM
Last Post: ajtravis
  How I Got Fedora Linux to Boot From eMMC (or microSD, for that matter) whitecat23 4 11,840 01-03-2022, 10:32 AM
Last Post: whitecat23
