Keyboard charges, won't type - ERROR: I2C_RDWR failed: No such device or address
With a new PPP, I am on stock software (Manjaro-Plasma, I believe).
I have installed necessary packages for compiling megi's userland software for ppkb.
Too, I have compiled it, and added the system service as I explained (in the wrong sub-forum) here,
PinePhone Keyboard won't work. read_kb_reg(PPKB_SYS_CONFIG) needs what? - https://forum.pine64.org/showthread.php?tid=18476
My PPKB charges but won't type.
lsmod ends with
pinephone_keyboard
but has no instance of kb151.
With the PPP firmly seated in my PPKB (and charging, battery staying at 100%), I tried the command
build/ppkb-i2c-flasher --rom-in firmware/build/fw-user.bin write reset
and saw
I did
rmmod pinephone_keyboard
and repeated the above. I had the same result.
Installing i2c-tools
pacman -S i2c-tools
had no effect on the command above.
I did see the following.
i2cdetect -l
i2c-0 i2c      rk3x-i2c                        I2C adapter
i2c-1 i2c      rk3x-i2c                        I2C adapter
i2c-3 i2c      rk3x-i2c                        I2C adapter
i2c-4 i2c      rk3x-i2c                        I2C adapter
i2c-5 i2c      rk3x-i2c                        I2C adapter
i2c-9 i2c      i2c-4-mux (chan_id 0)          I2C adapter
I can not blacklist anything b/c
update-initramfs -u
bash: update-initramfs: command not found
I installed both
mkinitcpio
mkinitcpio-busybox
and still can not update-initramfs.
As a user posted here,
keyboard case charging but not typing - https://forum.pine64.org/showthread.php?tid=17464
with the PPP firmly seated in the PPKB and booted therein, I too found,
dmesg | grep keyboard
pinephone-keyboard 2-0015: Keyboard was not found on the I2C bus, maybe it's disconnected.
How do I get "such device or address", shown above?
  Keyboard availability? KaylaMarie81 9 6,549 08-04-2025, 08:37 PM
Last Post: Peter Gamma
  Keyboard not working PPP is support broken atm? joshndroid 13 16,516 02-24-2024, 01:59 PM
Last Post: mburns
  The XIT bluetooth folding keyboard can work with the Pinephone Pro mburns 0 2,494 11-09-2023, 10:57 AM
Last Post: mburns
  Fixing the PinePhone Keyboard for the Linux Console mburns 0 2,730 09-02-2023, 07:48 AM
Last Post: mburns
  Power pass through USB-C dock that works? (HDMI out and charges phone) jcun4128 8 13,057 01-15-2023, 08:41 PM
Last Post: fox95
Bug Keyboard Power Issues Merc 13 21,897 05-02-2022, 09:41 AM
Last Post: dgiffin
  Checking Keyboard Charging Status dgiffin 0 4,266 04-23-2022, 03:40 AM
Last Post: dgiffin
  Use keyboard case as virtual mouse EwigeBlumenkraft 1 5,874 03-24-2022, 05:22 AM
Last Post: magdesign
  Hardware keyboard top row keycodes problem cyrelk 2 6,369 03-03-2022, 03:01 AM
Last Post: cyrelk
  Keyboard case issues dgiffin 10 19,037 03-03-2022, 12:56 AM
Last Post: tcoulon
