New out of box phone, vibrates and solid red light on charging
Just got new in box Pine Phone Pro, i pulled tape off battery.  reinserted, used usbC cable supplied and different chargers.
However, no matter what I try, the phone just vibrates endlessly and has a solid red light when connecting cable.
(03-24-2023, 11:32 AM)StuckInTheCloud Wrote: Just got new in box Pine Phone Pro, i pulled tape off battery.  reinserted, used usbC cable supplied and different chargers.
The battery probably discharged too much, so it can't continue to boot in that state. I would suggest to remove the cable and to power the device off, then hold the "volume up" button and reinsert the cable to make it boot into Tow-Boot's USB Mass Storage mode. The LED should turn blue while doing so. Let it charge there for multiple hours. If that didn't fix it you can also overwrite the eMMC from there.
  No phone call audio, logs posted, modem can't init audio? biketool 12 5,495 12-22-2025, 05:09 PM
  slight bumps causing phone to turn off. JadenSki 2 1,834 11-11-2025, 02:05 PM
Last Post: JadenSki
  USB charging is unreliable lightwo 0 2,201 05-17-2024, 04:29 AM
Last Post: lightwo
  PinePhonePro turns on when connecting usb charging cable xt0 5 6,853 10-10-2023, 12:01 PM
Last Post: zetabeta
  Question on the keyboard battery with phone knoxvilles_joker 0 3,211 08-27-2022, 12:04 AM
Last Post: knoxvilles_joker
  Warning!!- sim card adapter destroyed my sim card holder on my pine phone pro ANDROID2468 11 19,071 06-15-2022, 02:32 AM
Last Post: fxc
  Pine Store : Pine phone Pro Parts ? bcnaz 7 11,330 04-08-2022, 09:45 PM
Last Post: bcnaz
  Pine Phone Pro issues gmastap 0 3,097 03-14-2022, 07:21 AM
Last Post: gmastap
Question Battery not charging when run down to 0. iwm 2 4,627 02-08-2022, 10:45 AM
Last Post: mburns
  charging indicator nristen 16 22,417 02-03-2022, 04:36 PM
Last Post: phelion
