nand-sata-install on RAID-1 array
Question
This afternoon I set up armbian (22.11.1/Bullseye) and a 2 SSD, Software, Raid-1 array (mdadm, /dev/md0) on my Rockpro64 following this guide. I hoped to put my OS and files on that Raid Array using the "nand-sata-install" script below for speed and redundancy.
(https://forum.armbian.com/topic/9622-arm...ausb-drive)
Quote:sudo /usr/sbin/nand-sata-install
When I run "sudo /usr/sbin/nand-sata-install"
  • Choose "Boot from SPI - system on SATA, USB, or NVMe"
  • Select "1  /dev/md0" as the destination (the only option)
  • Press continue to the warning prompt "This script will erase your device /dev/md0. Continue?"
  • Select filesystem type ext4
I get the following output:
Quote:Partition too small. Needed: 1927 MB Avaliable:  MB
When I tried cfdisk to create a partition, cfdisk outputs the following warning:
Quote:Device already contains a linux_raid_member signature; it will be removed by a write command.
I am hesitant to add a partition using cfdisk since I don't want it to cause issues with the raid array.
Questions:
  • Is there any way to create a partition or expand the current partition without deleting the array?
  • Should I create partitions on those drives before I make the RAID array?
  • Is LVM a viable solution?
  • Am I approaching this incorrectly or missing a whole component of this process?
Similar issue without raid complications:
https://forum.armbian.com/topic/17155-pa...a-install/
End Goal for Context:
Run a fast Nextcloud instance on top of OMV (using docker) so that I have a reliable cloud and file storage solution that allows me to work collaboratively without google, microsoft, or other privacy abusing dependancies.
pine64 has nothing to do with software made by armbian.
  Install Mali 400 Drivers for Debian 11 on RockPro64 MaverickPi 2 6,629 02-19-2022, 06:44 AM
Last Post: sigmaris
  Power supply underpowered for Rockpro64, deficient PCIe SATA card, or something else? daffy 8 13,960 05-20-2021, 10:04 PM
Last Post: t4_4t
  Best way to avoid SMP internal errors when building RAID? kuleszdl 1 4,007 02-26-2021, 07:23 PM
Last Post: kuleszdl
  How To Lay Hands on a True 64-bit Debian Install? vandys 4 8,353 12-01-2020, 06:12 AM
Last Post: as365n4
  Bringing up a fresh Debian install (or trying) foresto 2 8,484 08-09-2020, 01:57 PM
Last Post: foresto
  Upgrade Debian kernel on a SD/SATA drive boot combo. linuxha 6 14,469 12-12-2019, 04:43 AM
Last Post: dukla2000
  PCIe Sata II adapter and ssd TRIM bavay 0 3,229 08-16-2019, 07:49 AM
Last Post: bavay
  Is it possible to install a clean and official version of Ubuntu? eduapof 4 8,587 05-25-2019, 05:08 AM
Last Post: pfeerick
  disappearing sata drives Mentaluproar 2 5,523 05-18-2019, 09:44 PM
Last Post: Mentaluproar
  Marvell 88SE9235 PCI SATA card in LibreELEC StefanRvO 6 13,105 05-18-2019, 04:21 AM
Last Post: p1x3l3d
