Greetings, my first post hire
So i'm planning to connect Bosch tool battery (18V) to Pinecill v2.
The adapter for battery comes with option to use fuse, but ones that are used in cars.
Question is what fuse would be the best one to put hire; like what voltage, amperage? I also heard of quality ceramic fuses...
I'm guessing using one that would brake if 24V or 3.8A is reached (just a guess )
Another question is there to be bought multi-core silicone cable (2 cores) that is same quality as one that Pine64 USB cables are made of,
so temperature heat resistance up to 350°C and super smooth feeling.
