PinePhone convergence docking bar malfunctioning
I have PinePhone (3GB variant) with Pine''s convergence docking bar. It worked fine for a while, though there were some occasional bugs (e.g. usb-c power don't work or docking bar no longer recognized and pinephone reboot is needed for bar to work again). But later eth port, hdmi and usb-c ceased to work at all: the phone is no longer charged via bar's usb-c, eth port is not visible (leds are down, no eth device created) and HDMI output no longer works. Both USB-A ports still work fine (I can connect mouse/keyborad/USB flash to the pinephone) and USB-C seems to provide power to the USB-A devices (e.g. usb mouse diode is turned on when I connect it to the docking bar with power plugged in into usb-c port while disconnected from the pinephone).
First I though this is some software bug, but reverting to older kernel where it worked doesn't help. Then I updated ANX7688 firmware from Megi's tree, but the bug is still here. It is possible that there is physical damage to the docking station, because I carried it often in the backpack, but there is no visible damage on the bar or its cable.
Have anyone encountered similar problem? Maybe this is a known issue I'm struggling about.
Any thoughts?
How convergence docking bar casing can be opened safely? Looks like it has some internal hatches, but I'm not sure. I want to examine internals for some obvious problem like broken circuit soldering.
(11-05-2022, 04:45 AM)bircoph Wrote: Hello,
Any thoughts?
Hi.
I have exactly the same issue: lsusb shows only the "1a40:0101 Terminus Technology Inc. Hub" device, and there is no HDMI output and no LAN. Excepting PinePhone I connected the docking bar to an Android smartphone with a PD charger. Does anybody know, is it a hardware or software issue?
It can be either hardware or power supply to the dock.
Make sure the cable is plugged into a sufficient power supply wall plug.
Sometimes you may have to flip the USB C cable and then reattach.
You might find that it operates best when left alone. If you unplug and plug in elsewhere there may be some issues.
I have a total of three docks and two are Pine64 docks and they work fine however another Pine dock I had failed to operate at all.
I also have an additional dock by another company and it works reasonably well.
Somewhere in the comments there are power supply requirements listed out.
Also try unplugging other things in a wall outlet so the dock is the only item being power supplied.
Good luck.
TESTED: Arch Plasma, Arch Phosh , Manjaro Phosh, Manjaro Plasma
Fedora, Mobian, Postmarket Plasma, Postmarket Phosh, Kali, SXMO.
(12-07-2022, 02:01 PM)Chief Wrote: Make sure the cable is plugged into a sufficient power supply wall plug.
I have tried different adapters.
Quote:Sometimes you may have to flip the USB C cable and then reattach.
Tried this as well.
Quote:I have a total of three docks and two are Pine64 docks and they work fine however another Pine dock I had failed to operate at all.
Any idea how to disassemble one?
  Pinephone (Pro) Keyboard Case for sale manubert 8 19,210 05-15-2026, 11:36 AM
Last Post: oliveira11670
  NEW pinephone keyboard case and LoRa backplate for sale ragele 0 2,973 01-12-2026, 06:09 PM
Last Post: ragele
  Replacement battery for PinePhone? j_s 9 10,709 06-03-2025, 04:19 PM
Last Post: j_s
  Searching for a PinePhone Keyboard Case RubiksCube 1 5,422 10-07-2024, 11:08 PM
  So which keyboard you suggest for the Pinephone? Peter Gamma 21 23,192 07-19-2024, 08:05 AM
Last Post: Peter Gamma
  Keyboards for the PinePhone? Peter Gamma 1 5,402 07-04-2024, 10:22 PM
  Bring the Pinephone keyboard back, it is worth it! Peter Gamma 1 5,261 07-04-2024, 07:32 AM
Heart The Pinephone keyboard offers alternative layouts Peter Gamma 0 3,138 07-04-2024, 05:40 AM
  Keyboard & 2.4G usb dongle for the Pinephone? Peter Gamma 2 4,949 06-29-2024, 09:36 PM
  Was someone able to use the Pinephone keyboard & an usb mouse at the same? Peter Gamma 4 12,688 06-26-2024, 07:11 AM
Last Post: dachalife
