Alternative power supply
I need a new power supply. I have an unused Mean Well  LPV-60-5 (5v 12A) led driver power supply
https://www.meanwell-web.com/en-gb/ac-dc...lpv--60--5
It will be safe and works fine to power my  rock64 board?
Thanks in avance
  DeskPi case alternative for ROCK64 v1k699 2 13,378 05-29-2025, 06:57 PM
Last Post: ameridroid
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 1 3,571 03-24-2025, 06:41 PM
Last Post: arunkhan
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 21,882 01-15-2023, 10:36 AM
Last Post: ds00
  power connector type please AlexS 4 10,349 01-11-2023, 07:00 AM
Last Post: dmitrymyadzelets
  Which Voltage and Amper to supply both Rock64 + External drive enclosure ? prog-amateur 0 4,034 08-21-2020, 09:16 PM
Last Post: prog-amateur
  Power Supply and Sinks for multi-Rock64 env Davo-CC 1 6,427 01-02-2020, 02:26 PM
Last Post: dpgraham
  Using a stronger power supply myn4m3 1 4,804 06-23-2019, 05:01 PM
Last Post: Rocklobster
  USB3 enough to power 2,5 external HDD? va88 11 23,661 06-06-2019, 03:40 PM
Last Post: va88
  How to check if my power supply is underperforming? va88 3 7,746 06-02-2019, 05:59 PM
Last Post: va88
  "ROCK 64 STEREO AUDIO DAC ADD-ON BOARD", Is it okay if I turn on the power ? t4_4t 4 10,411 01-09-2019, 01:02 AM
Last Post: t4_4t
