turn off display after inactivity
May seem a trivial issue... but there is a way to turn off the screen after an inactivity period?
I am using a pine 64, latest rooted android installed (5.1.1) to run kodi.
On android only thing i can do is to exit kodi after a timeout, but there is no option to turn off monitor/system unlike kodi for pc.
So I am looking for an alternative way to turn off the hdmi signal from the pine64 so that the tv will shutdown after no source signal is detected.
should be in settings /display and it is called sleep timer for a period of time with no activity.
(06-04-2016, 04:12 PM)dkryder Wrote: should be in settings /display and it is called sleep timer for a period of time with no activity.
Thanks, already tried but didn't work. To make it work I had also to disable the option "Never sleep while charging" in Settings/Developer Options.
the app tasker probably has a setting to do this
  Android 6.0 How to turn the screen back on modsbyus 4 9,521 11-28-2017, 01:03 PM
Last Post: modsbyus
  display problem florianl 6 12,131 06-11-2016, 10:12 AM
Last Post: kiko
  Anyone seeing occasional display stuttering? rakib-hasan 2 5,964 04-29-2016, 05:43 AM
Last Post: tkaiser
  Display too large for TV slamminsalmon 1 4,680 04-04-2016, 10:54 PM
Last Post: arpanj2
  How to turn off and wake up display? JulianM 19 37,862 02-02-2016, 10:44 PM
Last Post: SkimMilk
