Installing linux images
Is there trick to creating the Linux image for the Quartz64?  I have no trouble burning and booting the Android 16MB emmc image but I have tried burning Armbian, Arch images and LibreElec to emmc and SD  and I don't get the the kernel logo (or any HDMI) from them.  I've tried burning with Windows and Ubuntu.
The SD image contend look find when they are mounted in Android.
Thanks,
Martin
I have not tested the eMMC variant with Android (it may be necessary to disconnect the module from the motherboard). If you have previously recorded an old system to the SD card, perform a complete cleaning of the SD card before recording the new system. This is a known issue with the old GPT schema (from old images).
Please attach an UART adapter to get console output in order to debug this further.
Occasional Linux Kernel Contributor, Avid Wiki Updater, Ask Me About Quartz64
Open Hardware Quartz64 Model A TOSLink Adapter
Pi-bus GPIO Extender For ROCKPro64 And Quartz64 Model A
Plebian GNU/Linux
(07-06-2022, 01:08 AM)CounterPillow Wrote: Please attach an UART adapter to get console output in order to debug this further.
It is very likely to make a conclusion without the UART console.  Smile
Android on eMMC uses the old boot scheme, which is not compatible with new Linux systems. You need to either disable the eMMC module from Android and check the launch of a clean system only from the SD card, or erase the Android, or update the bootloader in Android (eMMC) to support the launch of any systems.
as CounterPillow says, you really need a compatible UART adapter to make much progress with these boards. I think that most of us use this one
https://pine64.com/product/serial-consol...r-edition/
Whilst you are waiting for it to arrive :-) can you get Linux to boot on a microSD card?
You could try boot the pgwipeout image on microSD as described here https://wiki.pine64.org/wiki/Quartz64#pg...uartz64_CI
if you can get that to work then there are line by line instructions to install Debian onto an eMMC here https://wiki.pine64.org/wiki/Installing_...e_Quartz64
When I say I can boot any Linux or LE via SD card that would be with no emmc card in.
I also see nothing on the console on UART0 via pin 12/14 in minicomm at various baudrate. This /dev/ttyUSB0 device works fine with other devices Should I be using UART2?
I do have BAT1 open and I have read that might need to be closed.
Martin
(07-06-2022, 11:12 AM)emveepee Wrote: When I say I can boot any Linux or LE via SD card that would be with no emmc card in.
Martin
Write more precisely, what do you want to get at the output? Running Linux with eMMC (with support for automatically starting other systems from an SD card if you connect an SD card)? Or do you want to have Android on eMMC and run from a Linux SD card?
Martin
you need to connect to UART2 at 1.5 mbauds. Also, the BAT ON/OFF jumper needs to be closed if you don't have a battery connected, otherwise you will run into boot failures.
Plebian GNU/Linux
Thanks the issue was the missing jumper on BAT1. Adding it all images boot and I also get a console on UART2 which was also not available.
I contacted my vendor Ameridroid to let them know this jumper should be provided with the order.
Martin
  irradium (based on crux linux) Quartz64 riscv64, aarch64 mara 8 19,048 03-07-2026, 04:21 PM
  SOQuartz Linux Builds stormwyrm 1 3,845 11-13-2023, 02:53 AM
Last Post: diederik
  Plebian Linux CounterPillow 8 12,926 07-19-2023, 08:51 AM
Last Post: CounterPillow
  Mainline linux Mwo87 4 9,056 07-06-2022, 05:38 AM
  Debian Userland on top of existing Linux build? dieselnutjob 3 7,069 01-25-2022, 01:12 PM
Last Post: dieselnutjob
  how to compile Linux from the SDK ? dieselnutjob 7 13,470 11-19-2021, 03:34 PM
  Boot Linux on microSD card? dieselnutjob 2 6,568 10-01-2021, 05:15 PM
