How can one change eg25-g modem software?
I have seen references in these threads stating that eg25-g is firmware/software running the modem.  Is this one file or a directory of files?
My PPP does not find the sim card and make phone calls as it once did.  I have attributed the inability to make calls to a hardware failure of the sd/sim card holder after repeated uses.  Perhaps, as an alternative, the modem software has gotten corrupted and this has stopped sim card calling. SD installed system runs  manjaro-phosh.
I would like to reinstall eg25-g but I don't know where it resides in the phone software.  I don't know where to get a new copy.  I have manjaro-phosh running from an sd card. This allows use of pacman.  I use "snowflake" ssh which provides both a terminal and a gui file manager to manipulate files between PC and PPP or edit files on PPP.
Anyone with any instructions on how to reinstall eg25-g with a fresh copy?
tom kosvic
Install gnome-firmware:
sudo pacman -S gnome-firmware
then run from terminal: sudo gnome-firmware
you get a gui where you can flash the modem... make sure you are connected to a charger
see here: https://wiki.pine64.org/wiki/PinePhone#Firmware_update
and here: https://forum.pine64.org/showthread.php?tid=16567
  DeviceNotReady After flashing modem firmware nekonosuke 4 6,660 02-13-2024, 11:36 PM
Last Post: nekonosuke
  asking for CLI-friendly software recommendations andrew907 9 9,934 11-18-2023, 07:54 AM
Last Post: crocspot
  Mobian Phosh Gnome Software Is Recommending A Broken Update. mburns 0 2,119 10-14-2023, 11:57 AM
Last Post: mburns
  Pinephone(pro) modem bug / shortcomings MadameMalady 2 5,153 06-19-2023, 03:40 PM
Last Post: MadameMalady
  Gnome settings crashes in Mobian after magnification change. mburns 2 3,988 11-24-2022, 07:23 AM
Last Post: mburns
  Modem turns off on suspend twzorek95 5 8,477 05-06-2022, 01:51 PM
Last Post: ertizpau
  Bluetooth sync software adamfowleruk 1 3,464 03-21-2022, 12:44 PM
  Modem unreliable on the PPP with Mobian EwigeBlumenkraft 2 4,450 03-17-2022, 02:11 AM
Last Post: EwigeBlumenkraft
