Telephony Dead
For a short time after installing Biktorgj's firmware I was able to sometimes make and receive calls though audio was poor and they often terminated.
However after some upgrades (one of which included modemmanager) that ended.  The modemmanager log now produces
  <info>  [modem1] simple connect state (8/8): all done
  <info>  [modem1] 3GPP registration state changed (home -> searching)
  <warn>  [modem1] couldn't load operator code: Current operator MCC/MNC is still unknown
  <warn>  [modem1] couldn't load operator name: Current operator id is still unknown
  <info>  [modem1] state changed (connected -> disconnecting)
  <info>  [modem1] state changed (disconnecting -> searching)
and then loops forever with
  <info>  [modem1] 3GPP registration state changed (searching -> idle)
  <info>  [modem1] state changed (searching -> enabled)
  <info>  [modem1] simple connect started...
  <info>  [modem1] simple connect state (4/8): wait to get fully enabled
  <info>  [modem1] simple connect state (5/8): register
  <info>  [modem1] 3GPP registration state changed (idle -> searching)
  <info>  [modem1] state changed (enabled -> searching)
With frequent interjections of
Evidently this problem is unique to my Pinephone.  I guess it's going to have to become a PDA.
Perhaps someday an upgrade will happen to fix it.
Rebooting has no effect but power cycling by pulling the battery gets me
[/dev/cdc-wdm0] Allocating new client ID...
[/dev/cdc-wdm0] Registered 'wds' (version 1.67) client with ID '2'
<info> [modem0/bearer1] QMI IPv4 Settings:
<info> [modem0/bearer1] address: 100.151.236.32/26
<info> [modem0/bearer1] gateway: 100.151.236.33
<info> [modem0/bearer1] DNS #1: 10.177.0.34
<info> [modem0/bearer1] DNS #2: 10.177.0.210
<info> [modem0/bearer1] MTU: 1500
<info> [modem0] state changed (connecting -> connected)
<info> [modem0] simple connect state (8/8): all done
After that a few calls go through and then back to the old behavior.
It might be a long shot, but consider filing an Issue at Biktorgj's firmware repo? You may have stumbled on a bug. And if not, someone may be able to help you otherwise.
Cheers,
TRS-80
Protocols, not Platforms
The problem was present before I installed Biktorgj's firmware.
  Telephony stopped working biketool 5 7,109 03-06-2022, 03:30 AM
  SMS after dead battery antiX-Dave 4 10,006 06-05-2020, 08:11 PM
Last Post: antiX-Dave
