Extremely Dim Screen on PPP
I let my PPP battery die completely, and then after I charged it from dead with the RE button the screen was extremely dim. I couldn't even unlock the phone because I couldn't see the on-screen keyboard clearly. I powered it off and put in a micro sd with Mobian on it in and booted it up again and I am pretty sure it turns on, but now the screen is completely black, even when I boot from the emmc. What should I do?
On my Pro Pine phone : Mobian does not give any boot indicators, no boot light or vibration.
But it Does boot, just takes a bit of patience waiting while the screen is black.
On the initial first boot Mobian does re-size the OS to use the whole sd card.
This re-sizing step can take a long time if you are using a very large sd card.
For testing operating systems on both the Pro and the original Pine phones, I use 16 & 32gb micro-sd cards.
While Mobian does still have some known short-comings on the Pro operating systems, it does function.
>> It may help to try in a brightly lit room, I have read here on the forum, that when the screen is un-lit the writing
can sometimes be read in bright light.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
  PinePhone Pro Black Screen CrimsenRaven 3 5,663 11-13-2024, 09:33 PM
Last Post: twentyslimy
  A way to view or log the splash screen on Pinephone Pro running ArchLinux (Danctnix) PHLEMON 4 6,379 07-30-2024, 11:03 PM
Last Post: PHLEMON
  Pinephone pro replacement lcd screen Linuxuser3 0 2,703 04-27-2024, 05:42 AM
Last Post: Linuxuser3
  Pinephone Pro Screen Protector jydoxcen 11 10,623 12-21-2023, 07:58 AM
Last Post: zetabeta
  Broke Screen and fix it - Up Swipe not working. iwm 2 4,342 02-12-2023, 03:44 PM
Last Post: iwm
  Broke my screen Barugon 7 10,150 10-11-2022, 01:30 PM
Last Post: Juan_Mann
