ST7789V LCD problem (RAMWR does not work for me)
I am trying some baremetal project.
And stuck with two problems:
1st RAMWR does not work for me in code below. ST7789V accepts the data, but ignores it: display stays black. I can't find why.
2nd might come from first problem. I use STLink V2 and flash like:
1st window:
openocd.exe -s ..\scripts\ -f interface\stlink.cfg -f target\nrf52.cfg -c "bindto 0.0.0.0"
2nd window:
arm-none-eabi-gdb --batch -ex="target extended-remote 127.0.0.1:3333" -ex "monitor program c:/pine/mbr.bin 0x00000000" -ex "monitor reset"
arm-none-eabi-gdb -ex="target extended-remote 127.0.0.1:3333"
and in gdb I need to issue "r" command to have any effect.
I.E. reboot after flash does not happen by itself, also after program exec instead of reboot I have HardFault.
Display is not dead: latest infinitime works for me on that device.
Any hints?
                .syntax     unified
                .cpu        cortex-m4
                .arch       armv7e-m
                .thumb
                .section    .text,"ax"
                .balign     4
                .equ        GPIO_BASE,                      0x50000000
                .equ        GPIO_OUT,                       0x504
                .equ        GPIO_OUTSET,                    0x508
                .equ        GPIO_OUTCLR,                    0x50C
                .equ        GPIO_IN,                        0x510
                .equ        GPIO_DIR,                       0x514
                .equ        GPIO_DIRSET,                    0x518
                .equ        GPIO_DIRCLR,                    0x51C
                .equ        FLASH_SELECT,                   5
                .equ        LCD_SCK,                        2
                .equ        LCD_MOSI,                       3
                .equ        LCD_MISO,                       4
                .equ        LCD_SELECT,                     25
                .equ        LCD_COMMAND,                    18
                .equ        LCD_RESET,                      26
                .equ        LCD_BACKLIGHT_LOW,              14
                .equ        LCD_BACKLIGHT_MID,              22
                .equ        LCD_BACKLIGHT_HIGH,             23
                .equ        LCD_OUTPUTS_CONTROL_MASK,       (1<<LCD_SCK) | (1<<LCD_MOSI) | (1<<LCD_SELECT) | (1<<LCD_COMMAND) | (1<<LCD_RESET)
                .equ        LCD_OUTPUTS_BACKLIGHT_MASK,     (1<<LCD_BACKLIGHT_LOW) | (1<<LCD_BACKLIGHT_MID) | (1<<LCD_BACKLIGHT_HIGH)
                .equ        LCD_SPI_BASE,                   0x40003000
                .equ        LCD_SPI_ENABLE,                 0x500
                .equ        LCD_SPI_PSELSCK,                0x508
                .equ        LCD_SPI_PSELMOSI,               0x50C
                .equ        LCD_SPI_PSELMISO,               0x510
                .equ        LCD_SPI_RXD,                    0x518
                .equ        LCD_SPI_TXD,                    0x51C
                .equ        LCD_SPI_FREQUENCY,              0x524
                .equ        LCD_SPI_CONFIG,                 0x554
                .equ        LCD_SPI_EVENTS_READY,           0x108
                .equ        LCD_WIDTH,                      8
                .equ        LCD_HEIGHT,                     8
                .equ        LCD_FULL_BYTES_SIZE,            (LCD_WIDTH*LCD_HEIGHT)
                .equ        CMD_SWRESET,                    0x01
                .equ        CMD_SLPOUT,                     0x11
                .equ        CMD_COLMOD,                     0x3A
                .equ        CMD_NORON,                      0x13 // Normal Display Mode On
                .equ        CMD_INVOFF,                     0x20 // Display Inversion Off
                .equ        CMD_INVON,                      0x21 // Display Inversion On
                .equ        CMD_DISPOFF,                    0x28 // Display Off
                .equ        CMD_DISPON,                     0x29 // Display On
                .equ        CMD_CASET,                      0x2A // Column Address Set
                .equ        CMD_RASET,                      0x2B // Row Address Set
                .equ        CMD_RAMWR,                      0x2C // Memory Write
                .equ        CMD_RAMRD,                      0x2E // Memory Read
                .equ        CMD_MADCTL,                     0x36 // Memory Data Access Control
                .equ        CMD_VSCSAD,                     0x37 // Vertical Scroll Start Address of RAM
                .equ        CMD_RAMCTRL,                    0xB0 // RAM Control
                .equ        CMD_PORCTRL,                    0xB2 // Porch Setting
                .equ        CMD_CMD2EN,                     0xDF // Command 2 Enable
                .equ        PUSH_BUTTON_IN,                 13
                .equ        PUSH_BUTTON_OUT,                15
                .equ        GPIO_OUTPUTS_MASK,              FLASH_SELECT | LCD_OUTPUTS_CONTROL_MASK | LCD_OUTPUTS_BACKLIGHT_MASK
                .equ        GPIO_INPUTS_MASK,               (1<<LCD_MISO)
                .macro      Sleep Reg, Tacts
                MOV         \Reg, \Tacts
loop\@:
                SUBS        \Reg, 1
                BNE         loop\@
                .endm
__Vectors:
                .org        0
                .word       __initial_sp                    // Top of Stack
                .word       Reset_Handler                   // Reset Handler
                .word       NMI_Handler                     // NMI Handler
                .word       HardFault_Handler               // Hard Fault Handler
                .word       MemManage_Handler               // MPU Fault Handler
                .word       BusFault_Handler                // Bus Fault Handler
                .word       UsageFault_Handler              // Usage Fault Handler
                .word       0                               // 7  Reserved
                .word       0                               // 8  Reserved
                .word       0                               // 9  Reserved
                .word       0                               // 10 Reserved
                .word       SVCall_Handler                  // Supervisor Call Handler
                .word       DebugMonitor_Handler            // Debug Monitor Handler
                .word       0                               // 13 Reserved
                .word       PendSV_Handler                  // Deferred Supervisor Call Handler
                .word       SysTick_Handler                 // System Timer Handler
                .word       CLOCK_POWER_BPROT_Handler       // 00 Clock control / Power control / Block Protect
                .word       RADIO_Handler                   // 01 2.4 GHz radio
                .word       UARTE0_Handler                  // 02 Universal Asynchronous Receiver/Transmitter with EasyDMA
                .word       SPIM0_SPIS0_TWIM0_TWIS0_Handler // 03 SPI master 0 / SPI slave 0 / Two-wire interface master 0 / Two-wire interface slave 0
                .word       SPIM1_SPIS1_TWIM1_TWIS1_Handler // 04 SPI master 1 / SPI slave 1 / Two-wire interface master 1 / Two-wire interface slave 1
                .word       NFCT_Handler                    // 05 Near Field Communication Tag
                .word       GPIOTE_Handler                  // 06 GPIO Tasks and Events
                .word       SAADC_Handler                   // 07 Analog to digital converter
                .word       TIMER0_Handler                  // 08 Timer 0
                .word       TIMER1_Handler                  // 09 Timer 1
                .word       TIMER2_Handler                  // 0A Timer 2
                .word       RTC0_Handler                    // 0B Real-time counter 0
                .word       TEMP_Handler                    // 0C Temperature sensor
                .word       RNG_Handler                     // 0D Random number generator
                .word       ECB_AES_Handler                 // 0E Electronic Code Book (ECB) mode block encryption
                .word       CCM_AAR_Handler                 // 0F AES CCM Mode Encryption / Acelerated Address Resolver
                .word       WDT_Handler                     // 10 Watchdog timer
                .word       RTC1_Handler                    // 11 Real-time counter 1
                .word       QDEC_Handler                    // 12 Quadrature decoder
                .word       LPCOMP_Handler                  // 13 Low power comparator
                .word       COMP_Handler                    // 14 General purpose comparator
                .word       EGU0_SWI0_Handler               // 15 Event Generator Unit 0 / Software interrupt 0
                .word       EGU1_SWI1_Handler               // 16 Event Generator Unit 1 / Software interrupt 1
                .word       EGU2_SWI2_Handler               // 17 Event Generator Unit 2 / Software interrupt 2
                .word       EGU3_SWI3_Handler               // 18 Event Generator Unit 3 / Software interrupt 3
                .word       EGU4_SWI4_Handler               // 19 Event Generator Unit 4 / Software interrupt 4
                .word       EGU5_SWI5_Handler               // 1A Event Generator Unit 5 / Software interrupt 5
                .word       TIMER3_Handler                  // 1B Timer 3
                .word       TIMER4_Handler                  // 1C Timer 4
                .word       PWM0_Handler                    // 1D Pulse Width Modulation Unit 0
                .word       PDM_Handler                     // 1E Pulse Density Modulation (Digital Microphone Interface)
                .word       NVMC_Handler                    // 1F Non-Volatile Memory Controller
                .word       PPI_Handler                     // 20 Programmable Peripheral Interconnect
                .word       MWU_Handler                     // 21 Memory Watch Unit
                .word       PWM1_Handler                    // 22 Pulse Width Modulation Unit 1
                .word       PWM2_Handler                    // 23 Pulse Width Modulation Unit 2
                .word       SPIS2_Handler                   // 24 SPI slave 2
                .word       SPIM2_Handler                   // 25 SPI master 2
                .word       RTC2_Handler                    // 26 Real-time counter 2
                .word       I2S_Handler                     // 27 Inter-IC Sound Interface
                .word       FPU_Handler                     // 28 FPU interrupt
                .word       ISR_29_Handler                  // 29 ISR_Handler
                .word       ISR_2A_Handler                  // 2A ISR_Handler
                .word       ISR_2B_Handler                  // 2B ISR_Handler
                .word       ISR_2C_Handler                  // 2C ISR_Handler
                .word       ISR_2D_Handler                  // 2D ISR_Handler
                .word       ISR_2E_Handler                  // 2E ISR_Handler
                .word       ISR_2F_Handler                  // 2F ISR_Handler
NMI_Handler:                                                // NMI Handler
                B           Reset
HardFault_Handler:                                          // Hard Fault Handler
                B           Reset
MemManage_Handler:                                          // MPU Fault Handler
                B           Reset
BusFault_Handler:                                           // Bus Fault Handler
                B           Reset
UsageFault_Handler:                                         // Usage Fault Handler
                B           Reset
SVCall_Handler:                                             // Supervisor call Handler
                B           Reset
DebugMonitor_Handler:                                       // Debug Monitor Handler
                B           Reset
PendSV_Handler:                                             // Deferred Supervisor Call Handler
                B           Reset
SysTick_Handler:                                            // System Timer Handler
                B           Reset
CLOCK_POWER_BPROT_Handler:                                  // 00 Clock control / Power control / Block Protect
                B           Reset
RADIO_Handler:                                              // 01 2.4 GHz radio
                B           Reset
UARTE0_Handler:                                             // 02 Universal Asynchronous Receiver/Transmitter with EasyDMA
                B           Reset
SPIM0_SPIS0_TWIM0_TWIS0_Handler:                            // 03 SPI master 0 / SPI slave 0 / Two-wire interface master 0 / Two-wire interface slave 0
                B           .
SPIM1_SPIS1_TWIM1_TWIS1_Handler:                            // 04 SPI master 1 / SPI slave 1 / Two-wire interface master 1 / Two-wire interface slave 1
                B           .
NFCT_Handler:                                               // 05 Near Field Communication Tag
                B           .
GPIOTE_Handler:                                             // 06 GPIO Tasks and Events
                B           .
SAADC_Handler:                                              // 07 Analog to digital converter
                B           .
TIMER0_Handler:                                             // 08 Timer 0
                B           .
TIMER1_Handler:                                             // 09 Timer 1
                B           .
TIMER2_Handler:                                             // 0A Timer 2
                B           .
RTC0_Handler:                                               // 0B Real-time counter 0
                B           .
TEMP_Handler:                                               // 0C Temperature sensor
                B           .
RNG_Handler:                                                // 0D Random number generator
                B           .
ECB_AES_Handler:                                            // 0E Electronic Code Book (ECB) mode block encryption
                B           .
CCM_AAR_Handler:                                            // 0F AES CCM Mode Encryption / Acelerated Address Resolver
                B           .
WDT_Handler:                                                // 10 Watchdog timer
                B           .
RTC1_Handler:                                               // 11 Real-time counter 1
                B           .
QDEC_Handler:                                               // 12 Quadrature decoder
                B           .
LPCOMP_Handler:                                             // 13 Low power comparator
                B           .
COMP_Handler:                                               // 14 General purpose comparator
                B           .
EGU0_SWI0_Handler:                                          // 15 Event Generator Unit 0 / Software interrupt 0
                B           .
EGU1_SWI1_Handler:                                          // 16 Event Generator Unit 1 / Software interrupt 1
                B           .
EGU2_SWI2_Handler:                                          // 17 Event Generator Unit 2 / Software interrupt 2
                B           .
EGU3_SWI3_Handler:                                          // 18 Event Generator Unit 3 / Software interrupt 3
                B           .
EGU4_SWI4_Handler:                                          // 19 Event Generator Unit 4 / Software interrupt 4
                B           .
EGU5_SWI5_Handler:                                          // 1A Event Generator Unit 5 / Software interrupt 5
                B           .
TIMER3_Handler:                                             // 1B Timer 3
                B           .
TIMER4_Handler:                                             // 1C Timer 4
                B           .
PWM0_Handler:                                               // 1D Pulse Width Modulation Unit 0
                B           .
PDM_Handler:                                                // 1E Pulse Density Modulation (Digital Microphone Interface)
                B           .
NVMC_Handler:                                               // 1F Non-Volatile Memory Controller
                B           .
PPI_Handler:                                                // 20 Programmable Peripheral Interconnect
                B           .
MWU_Handler:                                                // 21 Memory Watch Unit
                B           .
PWM1_Handler:                                               // 22 Pulse Width Modulation Unit 1
                B           .
PWM2_Handler:                                               // 23 Pulse Width Modulation Unit 2
                B           .
SPIS2_Handler:                                              // 24 SPI slave 2
                B           .
SPIM2_Handler:                                              // 25 SPI master 2
                B           .
RTC2_Handler:                                               // 26 Real-time counter 2
                B           .
I2S_Handler:                                                // 27 Inter-IC Sound Interface
                B           .
FPU_Handler:                                                // 28 FPU interrupt
                B           .
ISR_29_Handler:                                             // 29 ISR Handler
                B           .
ISR_2A_Handler:                                             // 2A ISR Handler
                B           .
ISR_2B_Handler:                                             // 2B ISR Handler
                B           .
ISR_2C_Handler:                                             // 2C ISR Handler
                B           .
ISR_2D_Handler:                                             // 2D ISR Handler
                B           .
ISR_2E_Handler:                                             // 2E ISR Handler
                B           .
ISR_2F_Handler:                                             // 2F ISR Handler
                B           .
Reset_Handler:
lcd_init:
                MOV         R7, GPIO_BASE
                LDR         R6, =LCD_SPI_BASE
                LDR         R0, =GPIO_OUTPUTS_MASK
                STR         R0, [R7, GPIO_DIRSET]
                LDR         R0, =GPIO_INPUTS_MASK
                STR         R0, [R7, GPIO_DIRCLR]
                MOV         R0, (1<<FLASH_SELECT)           // Deactivate FlashMemory
                STR         R0, [R7, GPIO_OUTSET]
                MOV         R0, (1<<LCD_SELECT)             // Activate Display
                STR         R0, [R7, GPIO_OUTCLR]
                MOV         R0, (1<<LCD_COMMAND)
                MOV         R0, (1<<LCD_RESET)
                LDR         R0, =LCD_OUTPUTS_BACKLIGHT_MASK
                MOV         R0, (1<<LCD_BACKLIGHT_HIGH)
                MOV         R0, 0
                STR         R0, [R6, LCD_SPI_ENABLE]
                MOV         R0, 0
                STR         R0, [R6, LCD_SPI_EVENTS_READY]
                MOV         R0, LCD_SCK
                STR         R0, [R6, LCD_SPI_PSELSCK]
                MOV         R0, LCD_MOSI
                STR         R0, [R6, LCD_SPI_PSELMOSI]
                MOV         R0, LCD_MISO
                STR         R0, [R6, LCD_SPI_PSELMISO]
                MOV         R0, 0x80000000                  // 8Mbps
                STR         R0, [R6, LCD_SPI_FREQUENCY]
                MOV         R0, (1<<2) | (1<<1)         // CPOL=ActiveLow | CPHA=Trailing | ORDER=MsbFirst
                STR         R0, [R6, LCD_SPI_CONFIG]
                //MOV           R0, 1
                //STR           R0, [R6, LCD_SPI_ENABLE]
                Sleep       R1, 0x1000000
                Sleep       R1, 0x1000000
                MOV         R0, CMD_SWRESET
                BL          lcd_transfer_cmd
                Sleep       R0, 0x1000000
                MOV         R0, CMD_SLPOUT
                BL          lcd_transfer_cmd
                Sleep       R0, 0x100000
                MOV         R0, CMD_VSCSAD
                BL          lcd_transfer_cmd
                MOV         R0, 0x00
                BL          lcd_transfer_data
                Sleep       R0, 0x10000
//              MOV         R0, CMD_CMD2EN
//              BL          lcd_transfer_cmd
//              MOV         R0, 0x5A
//              BL          lcd_transfer_data
//              MOV         R0, 0x69
//              MOV         R0, 0x02
//              MOV         R0, 0x01
//              Sleep       R0, 0x10000
//              MOV         R0, CMD_RAMCTRL
//              MOV         R0, 0x00
//              MOV         R0, 0xF0
//              MOV         R0, CMD_PORCTRL
//              MOV         R0, 0x0C
//              MOV         R0, 0x00
//              MOV         R0, 0x33
//              MOV         R0, 0x5A
//              MOV         R0, 0x69
//              MOV         R0, 0x02
//              MOV         R0, 0x00
                MOV         R0, CMD_COLMOD
                BL          lcd_transfer_cmd
                MOV         R0, 0x66                    // 888
                Sleep       R0, 0x100
                MOV         R0, CMD_MADCTL
                BL          lcd_transfer_cmd
                MOV         R0, 0x00
                Sleep       R0, 0x100
fill_display:
                MOV         R0, CMD_CASET
                BL          lcd_transfer_cmd
                MOV         R0, 0
                MOV         R0, LCD_WIDTH
                MOV         R0, CMD_RASET
                BL          lcd_transfer_cmd
                MOV         R0, 0
                MOV         R0, LCD_HEIGHT
                MOV         R0, CMD_RAMWR
                BL          lcd_transfer_cmd
                MOV         R3, 0xFFFFFFFF
fill_display_data1:
                LDR         R2, =LCD_FULL_BYTES_SIZE
fill_display_data:
                MOV         R0, R3
                MOV         R0, 0
                SUBS        R2, 1
                BNE         fill_display_data
                Sleep       R0, 0x100000
                MOV         R0, CMD_DISPOFF
                BL          lcd_transfer_cmd
                Sleep       R0, 0x100000
                MOV         R0, CMD_DISPON
                BL          lcd_transfer_cmd
                Sleep       R0, 0x100000
                //MOV         R0, (1<<LCD_SELECT)               // Deactivate Display
                //STR         R0, [R7, GPIO_OUTSET]
                Sleep       R0, 0x100000
                Sleep       R0, 0x100000
                //MOV         R0, (1<<LCD_SELECT)               // Activate Display
                //STR         R0, [R7, GPIO_OUTCLR]
                MOV         R0, CMD_INVON
                BL          lcd_transfer_cmd
                MOV         R0, CMD_NORON
                BL          lcd_transfer_cmd
                LSRS        R3, R3, 1
                BNE         fill_display_data1
                B           Reset
lcd_transfer_cmd:
                MOV         R1, (1<<LCD_SELECT)             // Activate Display
                STR         R1, [R7, GPIO_OUTCLR]
                MOV         R1, (1<<LCD_COMMAND)
                B           lcd_transfer
lcd_transfer_data:
                STR         R1, [R7, GPIO_OUTSET]
                B           lcd_transfer                    // Hang if removed: display needs time to sense command/data line
lcd_transfer:                                               // R6, R7, R0, R1
                MOV         R1, 1
                STR         R1, [R6, LCD_SPI_ENABLE]
                MOV         R1, 0
                STR         R1, [R6, LCD_SPI_EVENTS_READY]
                STR         R0, [R6, LCD_SPI_TXD]
lcd_transfer1:
                LDR         R1, [R6, LCD_SPI_EVENTS_READY]
                ORRS        R1, R1
                BNE         lcd_transfer1
                LDR         R1, [R6, LCD_SPI_RXD]
                MOV         R1, 0
                BX          LR
Reset:
                MOV         R0, 0xE000E000                  // #define SCS_BASE            (0xE000E000UL)                            /*!< System Control Space Base Address */
                ADD         R0, 0x0D00                      // #define SCB_BASE            (SCS_BASE +  0x0D00UL)                    /*!< System Control Block Base Address */
                ADD         R0, 0x00C                       // __IOM uint32_t AIRCR;      /*!< Offset: 0x00C (R/W)  Application Interrupt and Reset Control Register */
                LDR         R1, [R0]
                MOV         R2, 0xFFFF
                AND         R1, R2
                MOV         R2, 0x05FA
                LSL         R2, R2, 16
                ORR         R1, R2
                ORR         R1, (1<<2)                      // #define SCB_AIRCR_SYSRESETREQ_Pos 2U /*!< SCB AIRCR: SYSRESETREQ Position */
                STR         R1, [R0]
                B           .
                .equ        nextboot, 0x1000
                .equ        versionsize, 32
                .equ        __initial_sp, 0x20010000        // Top of Stack
                .equ        __initial_sp2_ptr, nextboot       // Top of Stack of next boot loader
                .pool
Compiled and gzipped code from the above: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I found one problem, though still no display output yet.
should be:
                .equ        GPIO_OUTPUTS_MASK,              (1<<FLASH_SELECT) | LCD_OUTPUTS_CONTROL_MASK | LCD_OUTPUTS_BACKLIGHT_MASK
  Fresh install and i can't get my device to work brenden_a 2 3,685 12-01-2023, 06:19 PM
Last Post: brenden_a
Question Which companion apps work best for flashing firmware and pairing/syncing w/ Pinetime? danimations 0 4,229 03-28-2022, 08:22 PM
Last Post: danimations
  problem: constant rebootting piner67 1 4,154 06-22-2021, 10:38 AM
Last Post: piner67
