ST7789V LCD problem (RAMWR does not work for me)
I am trying some baremetal project.
And stuck with two problems:
1st RAMWR does not work for me in code below. ST7789V accepts the data, but ignores it: display stays black. I can't find why.
2nd might come from first problem. I use STLink V2 and flash like:
1st window:
openocd.exe -s ..\scripts\ -f interface\stlink.cfg -f target\nrf52.cfg -c "bindto 0.0.0.0"
2nd window:
arm-none-eabi-gdb --batch -ex="target extended-remote 127.0.0.1:3333" -ex "monitor program c:/pine/mbr.bin 0x00000000" -ex "monitor reset"
arm-none-eabi-gdb -ex="target extended-remote 127.0.0.1:3333"
and in gdb I need to issue "r" command to have any effect.
I.E. reboot after flash does not happen by itself, also after program exec instead of reboot I have HardFault.
Display is not dead: latest infinitime works for me on that device.
Any hints?
                .syntax     unified                 .cpu        cortex-m4                 .arch       armv7e-m                 .thumb                 .section    .text,"ax"                 .balign     4                 .equ        GPIO_BASE,                      0x50000000                 .equ        GPIO_OUT,                       0x504                 .equ        GPIO_OUTSET,                    0x508                 .equ        GPIO_OUTCLR,                    0x50C                 .equ        GPIO_IN,                        0x510                 .equ        GPIO_DIR,                       0x514                 .equ        GPIO_DIRSET,                    0x518                 .equ        GPIO_DIRCLR,                    0x51C                 .equ        FLASH_SELECT,                   5                 .equ        LCD_SCK,                        2                 .equ        LCD_MOSI,                       3                 .equ        LCD_MISO,                       4                 .equ        LCD_SELECT,                     25                 .equ        LCD_COMMAND,                    18                 .equ        LCD_RESET,                      26                 .equ        LCD_BACKLIGHT_LOW,              14                 .equ        LCD_BACKLIGHT_MID,              22                 .equ        LCD_BACKLIGHT_HIGH,             23                 .equ        LCD_OUTPUTS_CONTROL_MASK,       (1<<LCD_SCK) | (1<<LCD_MOSI) | (1<<LCD_SELECT) | (1<<LCD_COMMAND) | (1<<LCD_RESET)                 .equ        LCD_OUTPUTS_BACKLIGHT_MASK,     (1<<LCD_BACKLIGHT_LOW) | (1<<LCD_BACKLIGHT_MID) | (1<<LCD_BACKLIGHT_HIGH)                 .equ        LCD_SPI_BASE,                   0x40003000                 .equ        LCD_SPI_ENABLE,                 0x500                 .equ        LCD_SPI_PSELSCK,                0x508                 .equ        LCD_SPI_PSELMOSI,               0x50C                 .equ        LCD_SPI_PSELMISO,               0x510                 .equ        LCD_SPI_RXD,                    0x518                 .equ        LCD_SPI_TXD,                    0x51C                 .equ        LCD_SPI_FREQUENCY,              0x524                 .equ        LCD_SPI_CONFIG,                 0x554                 .equ        LCD_SPI_EVENTS_READY,           0x108                                 .equ        LCD_WIDTH,                      8                 .equ        LCD_HEIGHT,                     8                 .equ        LCD_FULL_BYTES_SIZE,            (LCD_WIDTH*LCD_HEIGHT)                                 .equ        CMD_SWRESET,                    0x01                 .equ        CMD_SLPOUT,                     0x11                 .equ        CMD_COLMOD,                     0x3A                 .equ        CMD_NORON,                      0x13 // Normal Display Mode On                 .equ        CMD_INVOFF,                     0x20 // Display Inversion Off                 .equ        CMD_INVON,                      0x21 // Display Inversion On                 .equ        CMD_DISPOFF,                    0x28 // Display Off                 .equ        CMD_DISPON,                     0x29 // Display On                 .equ        CMD_CASET,                      0x2A // Column Address Set                 .equ        CMD_RASET,                      0x2B // Row Address Set                 .equ        CMD_RAMWR,                      0x2C // Memory Write                 .equ        CMD_RAMRD,                      0x2E // Memory Read                 .equ        CMD_MADCTL,                     0x36 // Memory Data Access Control                 .equ        CMD_VSCSAD,                     0x37 // Vertical Scroll Start Address of RAM                 .equ        CMD_RAMCTRL,                    0xB0 // RAM Control                 .equ        CMD_PORCTRL,                    0xB2 // Porch Setting                 .equ        CMD_CMD2EN,                     0xDF // Command 2 Enable                 .equ        PUSH_BUTTON_IN,                 13                 .equ        PUSH_BUTTON_OUT,                15                 .equ        GPIO_OUTPUTS_MASK,              FLASH_SELECT | LCD_OUTPUTS_CONTROL_MASK | LCD_OUTPUTS_BACKLIGHT_MASK                 .equ        GPIO_INPUTS_MASK,               (1<<LCD_MISO)                 .macro      Sleep Reg, Tacts                 MOV         \Reg, \Tacts loop\@:                 SUBS        \Reg, 1                 BNE         loop\@                 .endm __Vectors:                 .org        0                 .word       __initial_sp                    // Top of Stack                 .word       Reset_Handler                   // Reset Handler                 .word       NMI_Handler                     // NMI Handler                 .word       HardFault_Handler               // Hard Fault Handler                 .word       MemManage_Handler               // MPU Fault Handler                 .word       BusFault_Handler                // Bus Fault Handler                 .word       UsageFault_Handler              // Usage Fault Handler                 .word       0                               // 7  Reserved                 .word       0                               // 8  Reserved                 .word       0                               // 9  Reserved                 .word       0                               // 10 Reserved                 .word       SVCall_Handler                  // Supervisor Call Handler                 .word       DebugMonitor_Handler            // Debug Monitor Handler                 .word       0                               // 13 Reserved                 .word       PendSV_Handler                  // Deferred Supervisor Call Handler                 .word       SysTick_Handler                 // System Timer Handler                 .word       CLOCK_POWER_BPROT_Handler       // 00 Clock control / Power control / Block Protect                 .word       RADIO_Handler                   // 01 2.4 GHz radio                 .word       UARTE0_Handler                  // 02 Universal Asynchronous Receiver/Transmitter with EasyDMA                 .word       SPIM0_SPIS0_TWIM0_TWIS0_Handler // 03 SPI master 0 / SPI slave 0 / Two-wire interface master 0 / Two-wire interface slave 0                 .word       SPIM1_SPIS1_TWIM1_TWIS1_Handler // 04 SPI master 1 / SPI slave 1 / Two-wire interface master 1 / Two-wire interface slave 1                 .word       NFCT_Handler                    // 05 Near Field Communication Tag                 .word       GPIOTE_Handler                  // 06 GPIO Tasks and Events                 .word       SAADC_Handler                   // 07 Analog to digital converter                 .word       TIMER0_Handler                  // 08 Timer 0                 .word       TIMER1_Handler                  // 09 Timer 1                 .word       TIMER2_Handler                  // 0A Timer 2                 .word       RTC0_Handler                    // 0B Real-time counter 0                 .word       TEMP_Handler                    // 0C Temperature sensor                 .word       RNG_Handler                     // 0D Random number generator                 .word       ECB_AES_Handler                 // 0E Electronic Code Book (ECB) mode block encryption                 .word       CCM_AAR_Handler                 // 0F AES CCM Mode Encryption / Acelerated Address Resolver                 .word       WDT_Handler                     // 10 Watchdog timer                 .word       RTC1_Handler                    // 11 Real-time counter 1                 .word       QDEC_Handler                    // 12 Quadrature decoder                 .word       LPCOMP_Handler                  // 13 Low power comparator                 .word       COMP_Handler                    // 14 General purpose comparator                 .word       EGU0_SWI0_Handler               // 15 Event Generator Unit 0 / Software interrupt 0                 .word       EGU1_SWI1_Handler               // 16 Event Generator Unit 1 / Software interrupt 1                 .word       EGU2_SWI2_Handler               // 17 Event Generator Unit 2 / Software interrupt 2                 .word       EGU3_SWI3_Handler               // 18 Event Generator Unit 3 / Software interrupt 3                 .word       EGU4_SWI4_Handler               // 19 Event Generator Unit 4 / Software interrupt 4                 .word       EGU5_SWI5_Handler               // 1A Event Generator Unit 5 / Software interrupt 5                 .word       TIMER3_Handler                  // 1B Timer 3                 .word       TIMER4_Handler                  // 1C Timer 4                 .word       PWM0_Handler                    // 1D Pulse Width Modulation Unit 0                 .word       PDM_Handler                     // 1E Pulse Density Modulation (Digital Microphone Interface)                 .word       NVMC_Handler                    // 1F Non-Volatile Memory Controller                 .word       PPI_Handler                     // 20 Programmable Peripheral Interconnect                 .word       MWU_Handler                     // 21 Memory Watch Unit                 .word       PWM1_Handler                    // 22 Pulse Width Modulation Unit 1                 .word       PWM2_Handler                    // 23 Pulse Width Modulation Unit 2                 .word       SPIS2_Handler                   // 24 SPI slave 2                 .word       SPIM2_Handler                   // 25 SPI master 2                 .word       RTC2_Handler                    // 26 Real-time counter 2                 .word       I2S_Handler                     // 27 Inter-IC Sound Interface                 .word       FPU_Handler                     // 28 FPU interrupt                 .word       ISR_29_Handler                  // 29 ISR_Handler                 .word       ISR_2A_Handler                  // 2A ISR_Handler                 .word       ISR_2B_Handler                  // 2B ISR_Handler                 .word       ISR_2C_Handler                  // 2C ISR_Handler                 .word       ISR_2D_Handler                  // 2D ISR_Handler                 .word       ISR_2E_Handler                  // 2E ISR_Handler                 .word       ISR_2F_Handler                  // 2F ISR_Handler NMI_Handler:                                                // NMI Handler                 B           Reset HardFault_Handler:                                          // Hard Fault Handler                 B           Reset MemManage_Handler:                                          // MPU Fault Handler                 B           Reset BusFault_Handler:                                           // Bus Fault Handler                 B           Reset UsageFault_Handler:                                         // Usage Fault Handler                 B           Reset SVCall_Handler:                                             // Supervisor call Handler                 B           Reset DebugMonitor_Handler:                                       // Debug Monitor Handler                 B           Reset PendSV_Handler:                                             // Deferred Supervisor Call Handler                 B           Reset SysTick_Handler:                                            // System Timer Handler                 B           Reset CLOCK_POWER_BPROT_Handler:                                  // 00 Clock control / Power control / Block Protect                 B           Reset RADIO_Handler:                                              // 01 2.4 GHz radio                 B           Reset UARTE0_Handler:                                             // 02 Universal Asynchronous Receiver/Transmitter with EasyDMA                 B           Reset SPIM0_SPIS0_TWIM0_TWIS0_Handler:                            // 03 SPI master 0 / SPI slave 0 / Two-wire interface master 0 / Two-wire interface slave 0                 B           . SPIM1_SPIS1_TWIM1_TWIS1_Handler:                            // 04 SPI master 1 / SPI slave 1 / Two-wire interface master 1 / Two-wire interface slave 1                 B           . NFCT_Handler:                                               // 05 Near Field Communication Tag                 B           . GPIOTE_Handler:                                             // 06 GPIO Tasks and Events                 B           . SAADC_Handler:                                              // 07 Analog to digital converter                 B           . TIMER0_Handler:                                             // 08 Timer 0                 B           . TIMER1_Handler:                                             // 09 Timer 1                 B           . TIMER2_Handler:                                             // 0A Timer 2                 B           . RTC0_Handler:                                               // 0B Real-time counter 0                 B           . TEMP_Handler:                                               // 0C Temperature sensor                 B           . RNG_Handler:                                                // 0D Random number generator                 B           . ECB_AES_Handler:                                            // 0E Electronic Code Book (ECB) mode block encryption                 B           . CCM_AAR_Handler:                                            // 0F AES CCM Mode Encryption / Acelerated Address Resolver                 B           . WDT_Handler:                                                // 10 Watchdog timer                 B           . RTC1_Handler:                                               // 11 Real-time counter 1                 B           . QDEC_Handler:                                               // 12 Quadrature decoder                 B           . LPCOMP_Handler:                                             // 13 Low power comparator                 B           . COMP_Handler:                                               // 14 General purpose comparator                 B           . EGU0_SWI0_Handler:                                          // 15 Event Generator Unit 0 / Software interrupt 0                 B           . EGU1_SWI1_Handler:                                          // 16 Event Generator Unit 1 / Software interrupt 1                 B           . EGU2_SWI2_Handler:                                          // 17 Event Generator Unit 2 / Software interrupt 2                 B           . EGU3_SWI3_Handler:                                          // 18 Event Generator Unit 3 / Software interrupt 3                 B           . EGU4_SWI4_Handler:                                          // 19 Event Generator Unit 4 / Software interrupt 4                 B           . EGU5_SWI5_Handler:                                          // 1A Event Generator Unit 5 / Software interrupt 5                 B           . TIMER3_Handler:                                             // 1B Timer 3                 B           . TIMER4_Handler:                                             // 1C Timer 4                 B           . PWM0_Handler:                                               // 1D Pulse Width Modulation Unit 0                 B           . PDM_Handler:                                                // 1E Pulse Density Modulation (Digital Microphone Interface)                 B           . NVMC_Handler:                                               // 1F Non-Volatile Memory Controller                 B           . PPI_Handler:                                                // 20 Programmable Peripheral Interconnect                 B           . MWU_Handler:                                                // 21 Memory Watch Unit                 B           . PWM1_Handler:                                               // 22 Pulse Width Modulation Unit 1                 B           . PWM2_Handler:                                               // 23 Pulse Width Modulation Unit 2                 B           . SPIS2_Handler:                                              // 24 SPI slave 2                 B           . SPIM2_Handler:                                              // 25 SPI master 2                 B           . RTC2_Handler:                                               // 26 Real-time counter 2                 B           . I2S_Handler:                                                // 27 Inter-IC Sound Interface                 B           . FPU_Handler:                                                // 28 FPU interrupt                 B           . ISR_29_Handler:                                             // 29 ISR Handler                 B           . ISR_2A_Handler:                                             // 2A ISR Handler                 B           . ISR_2B_Handler:                                             // 2B ISR Handler                 B           . ISR_2C_Handler:                                             // 2C ISR Handler                 B           . ISR_2D_Handler:                                             // 2D ISR Handler                 B           . ISR_2E_Handler:                                             // 2E ISR Handler                 B           . ISR_2F_Handler:                                             // 2F ISR Handler                 B           . Reset_Handler: lcd_init:                 MOV         R7, GPIO_BASE                 LDR         R6, =LCD_SPI_BASE                                 LDR         R0, =GPIO_OUTPUTS_MASK                 STR         R0, [R7, GPIO_DIRSET]                 LDR         R0, =GPIO_INPUTS_MASK                 STR         R0, [R7, GPIO_DIRCLR]                 MOV         R0, (1<<FLASH_SELECT)           // Deactivate FlashMemory                 STR         R0, [R7, GPIO_OUTSET]                 MOV         R0, (1<<LCD_SELECT)             // Activate Display                 STR         R0, [R7, GPIO_OUTCLR]                 MOV         R0, (1<<LCD_COMMAND)                 STR         R0, [R7, GPIO_OUTSET]                 MOV         R0, (1<<LCD_RESET)                 STR         R0, [R7, GPIO_OUTSET]                                 LDR         R0, =LCD_OUTPUTS_BACKLIGHT_MASK                 STR         R0, [R7, GPIO_OUTSET]                 MOV         R0, (1<<LCD_BACKLIGHT_HIGH)                 STR         R0, [R7, GPIO_OUTCLR]                 MOV         R0, 0                 STR         R0, [R6, LCD_SPI_ENABLE]                                 MOV         R0, 0                 STR         R0, [R6, LCD_SPI_EVENTS_READY]                                 MOV         R0, LCD_SCK                 STR         R0, [R6, LCD_SPI_PSELSCK]                                 MOV         R0, LCD_MOSI                 STR         R0, [R6, LCD_SPI_PSELMOSI]                 MOV         R0, LCD_MISO                 STR         R0, [R6, LCD_SPI_PSELMISO]                 MOV         R0, 0x80000000                  // 8Mbps                 STR         R0, [R6, LCD_SPI_FREQUENCY]                 MOV         R0, (1<<2) | (1<<1)         // CPOL=ActiveLow | CPHA=Trailing | ORDER=MsbFirst                 STR         R0, [R6, LCD_SPI_CONFIG]                 //MOV           R0, 1                 //STR           R0, [R6, LCD_SPI_ENABLE]                 MOV         R0, (1<<LCD_RESET)                 STR         R0, [R7, GPIO_OUTCLR]                 Sleep       R1, 0x1000000                 STR         R0, [R7, GPIO_OUTSET]                 Sleep       R1, 0x1000000                 MOV         R0, CMD_SWRESET                 BL          lcd_transfer_cmd                 Sleep       R0, 0x1000000                                 MOV         R0, CMD_SLPOUT                 BL          lcd_transfer_cmd                 Sleep       R0, 0x100000                                 MOV         R0, CMD_VSCSAD                 BL          lcd_transfer_cmd                 MOV         R0, 0x00                 BL          lcd_transfer_data                 BL          lcd_transfer_data                 Sleep       R0, 0x10000                 //              MOV         R0, CMD_CMD2EN //              BL          lcd_transfer_cmd //              MOV         R0, 0x5A //              BL          lcd_transfer_data //              MOV         R0, 0x69 //              BL          lcd_transfer_data //              MOV         R0, 0x02 //              BL          lcd_transfer_data //              MOV         R0, 0x01 //              BL          lcd_transfer_data //              Sleep       R0, 0x10000 // //              MOV         R0, CMD_RAMCTRL //              BL          lcd_transfer_cmd //              MOV         R0, 0x00 //              BL          lcd_transfer_data //              MOV         R0, 0xF0 //              BL          lcd_transfer_data //              Sleep       R0, 0x10000 //              //              MOV         R0, CMD_PORCTRL //              BL          lcd_transfer_cmd //              MOV         R0, 0x0C //              BL          lcd_transfer_data //              BL          lcd_transfer_data //              MOV         R0, 0x00 //              BL          lcd_transfer_data //              MOV         R0, 0x33 //              BL          lcd_transfer_data //              BL          lcd_transfer_data //              Sleep       R0, 0x10000 //              //              MOV         R0, CMD_CMD2EN //              BL          lcd_transfer_cmd //              MOV         R0, 0x5A //              BL          lcd_transfer_data //              MOV         R0, 0x69 //              BL          lcd_transfer_data //              MOV         R0, 0x02 //              BL          lcd_transfer_data //              MOV         R0, 0x00 //              BL          lcd_transfer_data //              Sleep       R0, 0x10000                 MOV         R0, CMD_COLMOD                 BL          lcd_transfer_cmd                 MOV         R0, 0x66                    // 888                 BL          lcd_transfer_data                 Sleep       R0, 0x100                                 MOV         R0, CMD_MADCTL                 BL          lcd_transfer_cmd                 MOV         R0, 0x00                 BL          lcd_transfer_data                 Sleep       R0, 0x100 fill_display:                 MOV         R0, CMD_CASET                 BL          lcd_transfer_cmd                 MOV         R0, 0                 BL          lcd_transfer_data                 BL          lcd_transfer_data                 BL          lcd_transfer_data                 MOV         R0, LCD_WIDTH                 BL          lcd_transfer_data                 MOV         R0, CMD_RASET                 BL          lcd_transfer_cmd                 MOV         R0, 0                 BL          lcd_transfer_data                 BL          lcd_transfer_data                 BL          lcd_transfer_data                 MOV         R0, LCD_HEIGHT                 BL          lcd_transfer_data                 MOV         R0, CMD_RAMWR                 BL          lcd_transfer_cmd                 MOV         R3, 0xFFFFFFFF fill_display_data1:                 LDR         R2, =LCD_FULL_BYTES_SIZE fill_display_data:                 MOV         R0, R3                 BL          lcd_transfer_data                 MOV         R0, 0                 BL          lcd_transfer_data                 BL          lcd_transfer_data                 SUBS        R2, 1                 BNE         fill_display_data                                 Sleep       R0, 0x100000                 MOV         R0, CMD_DISPOFF                 BL          lcd_transfer_cmd                 Sleep       R0, 0x100000                                 MOV         R0, CMD_DISPON                 BL          lcd_transfer_cmd                 Sleep       R0, 0x100000                 //MOV         R0, (1<<LCD_SELECT)               // Deactivate Display                 //STR         R0, [R7, GPIO_OUTSET]                                 LDR         R0, =LCD_OUTPUTS_BACKLIGHT_MASK                 STR         R0, [R7, GPIO_OUTSET]                 Sleep       R0, 0x100000                 MOV         R0, (1<<LCD_BACKLIGHT_HIGH)                 STR         R0, [R7, GPIO_OUTCLR]                 Sleep       R0, 0x100000                 //MOV         R0, (1<<LCD_SELECT)               // Activate Display                 //STR         R0, [R7, GPIO_OUTCLR]                 MOV         R0, CMD_INVON                 BL          lcd_transfer_cmd                 MOV         R0, CMD_NORON                 BL          lcd_transfer_cmd                 LSRS        R3, R3, 1                 BNE         fill_display_data1                 LDR         R0, =LCD_OUTPUTS_BACKLIGHT_MASK                 STR         R0, [R7, GPIO_OUTSET]                 B           Reset lcd_transfer_cmd:                 MOV         R1, (1<<LCD_SELECT)             // Activate Display                 STR         R1, [R7, GPIO_OUTCLR]                 MOV         R1, (1<<LCD_COMMAND)                 STR         R1, [R7, GPIO_OUTCLR]                 B           lcd_transfer lcd_transfer_data:                 MOV         R1, (1<<LCD_SELECT)             // Activate Display                 STR         R1, [R7, GPIO_OUTCLR]                 MOV         R1, (1<<LCD_COMMAND)                 STR         R1, [R7, GPIO_OUTSET]                 B           lcd_transfer                    // Hang if removed: display needs time to sense command/data line lcd_transfer:                                               // R6, R7, R0, R1                 MOV         R1, 1                 STR         R1, [R6, LCD_SPI_ENABLE]                                 MOV         R1, 0                 STR         R1, [R6, LCD_SPI_EVENTS_READY]                 STR         R0, [R6, LCD_SPI_TXD] lcd_transfer1:                 LDR         R1, [R6, LCD_SPI_EVENTS_READY]                 ORRS        R1, R1                 BNE         lcd_transfer1                 LDR         R1, [R6, LCD_SPI_RXD]                                 MOV         R1, 0                 STR         R1, [R6, LCD_SPI_ENABLE]                 MOV         R1, (1<<LCD_SELECT)             // Activate Display                 STR         R1, [R7, GPIO_OUTSET]                 BX          LR Reset:                 MOV         R0, 0xE000E000                  // #define SCS_BASE            (0xE000E000UL)                            /*!< System Control Space Base Address */                 ADD         R0, 0x0D00                      // #define SCB_BASE            (SCS_BASE +  0x0D00UL)                    /*!< System Control Block Base Address */                 ADD         R0, 0x00C                       // __IOM uint32_t AIRCR;      /*!< Offset: 0x00C (R/W)  Application Interrupt and Reset Control Register */                 LDR         R1, [R0]                 MOV         R2, 0xFFFF                 AND         R1, R2                 MOV         R2, 0x05FA                 LSL         R2, R2, 16                 ORR         R1, R2                 ORR         R1, (1<<2)                      // #define SCB_AIRCR_SYSRESETREQ_Pos 2U /*!< SCB AIRCR: SYSRESETREQ Position */                 STR         R1, [R0]                 B           .                 .equ        nextboot, 0x1000                 .equ        versionsize, 32                 .equ        __initial_sp, 0x20010000        // Top of Stack                 .equ        __initial_sp2_ptr, nextboot       // Top of Stack of next boot loader                 .pool
Compiled and gzipped code from the above:
H4sICKoGS2ICAG1ici5iaW4AtdHNaxNBGMfxmZiGtURJ1UiQIokWadMiQaXWEOMmrUkQ7cbaivhG fCtFiiQ9eRFyUkQQevHsn+JBk3MuPXdOhZ5GiTIoNn4nGWvp3Swffvs8z+zsZlcImVyTQgiEEEYE nu3t+w3Ti7r+YTKGIziG40jgBEZxEkmcwhjOYBxpTOEsMjiHC5jGDLLIIQ8fRcyhhAqu4TrmUcUC FnEbd3AX9/EQNTzGUyxjBc+xiheoo6xK6qqaU7OqqArKV1dUXl1WObWz9b+OQH8sr8+vV9omMRTo mGibUTJJeqSot010KOg2k4O6WbP5ptKvukL0p1qIlhEuPRnokE3qA6Sdh8mYnfstM0ZGqBfdbnbe bMhLvzvuDv3zQPMy9AdDXZczth6hfm94ktigvkj92th7Cv3OCP3WzjKDWZbeS2bL5Cvbd3tMU6+6 axp7+mnqmus/Y68neETtUT8gJ8mqmy8xu4Wbbn6DnCJ9snc+0H4oURK66FbnWZkzMtvt/HvycfoT e/7JBHVqt864d+umf9/x7uoUq4fZ/SgZMfe8L53T/SvSm9yxwdo4a1M2vX0dL97ja0vJt4ozIb2R Fl97gzw4+6uzYRKu35837BX1cqA3k+J7tSa+RoVcCX701uR2SPrffi4E26FigfOCDktZ29kSGeEf 8j9HhP9J/AHvBpHwyAMAAA==
I found one problem, though still no display output yet.
should be:
                .equ        GPIO_OUTPUTS_MASK,              (1<<FLASH_SELECT) | LCD_OUTPUTS_CONTROL_MASK | LCD_OUTPUTS_BACKLIGHT_MASK
  Fresh install and i can't get my device to work brenden_a 2 3,818 12-01-2023, 06:19 PM
Last Post: brenden_a
Question Which companion apps work best for flashing firmware and pairing/syncing w/ Pinetime? danimations 0 4,437 03-28-2022, 08:22 PM
Last Post: danimations
  problem: constant rebootting piner67 1 4,265 06-22-2021, 10:38 AM
Last Post: piner67
