OMV 6 NAS - Image to use
Can someone be so kind to let me know what image should I use in order to install OMV 6.0 on top?
(03-18-2022, 04:32 AM)g_t_j Wrote: Can someone be so kind to let me know what image should I use in order to install OMV 6.0 on top?
Armbian and OMV have some sort of deal going from what I've read.
Ah it makes sense why I am having problems to install.
Any other OS which is recommended? (if possible a specific build that's been tested nad working without problems)
https://wiki.omv-extras.org/doku.php?id=...ian_buster
I'd use bullseye instead of buster but the install instructions are the same more or less...
That's what I tried. I can't get OMV to install on top of Armbian.
I finally got it to work using image:
Armbian_20.11.6_Rockpro64_buster_current_5.9.14.img
I write the process here for future reference.
Installed the image into the eMMC module booted it up and had to issue the command:
echo 0 >  /sys/devices/platform/pwm-fan/hwmon/hwmon3/pwm1
in order to stop the fan as it would run at full speed.
I then edited /etc/rc.local with nano ---->
nano /etc/rc.local
 and added at the end of the file and before exit:
rmmod pwm-fan echo 0 > /sys/class/pwm/pwmchip1/export echo 110 > /sys/class/pwm/pwmchip1/pwm0/duty_cycle echo 500 > /sys/class/pwm/pwmchip1/pwm0/period echo 1 > /sys/class/pwm/pwmchip1/pwm0/enable
Now the fan runs constantly but at very low speed which I believe is the best compromise between cooling and silence.
After that I run armbian-config  and navigated > System > 3rd party software and installed OMV.
All good. Thanks for your help!
  Recovery from bad SPI flash image hmuller 2 11,197 11-04-2020, 01:17 PM
Last Post: hmuller
