Wireless Charging merely @ 0.5 A (PP_Mobian)
Hello there,
my new wireless charging case is charging the Pinephone (Mobian Edition) merely at 0.5 A, but the case specs say it should be up to 1.2 A. The charger itself has an output of 15 W.
Any ideas how to boost the charging rate?
Thanks and cheers!
The latest update of powersupply to v0.6.0-1 solved the problem and now wireless charging is at full power (1.5A).
Good to hear - must add a case to my next order
(04-12-2022, 02:17 AM)arno_nuehm Wrote: The latest update of powersupply to v0.6.0-1 solved the problem and now wireless charging is at full power (1.5A).
Not for me. I received my wireless charging case yesterday and already had 0.6.0 installed. I'm using Manjaro Phosh (unstable branch). I have the Insignia 10W charging pad from Best Buy. It charges my Pixel 6 at ~1300mA.
Oh, that's bad. Here are my specs:
Pinephone (Mobian Edition, 3Gb) - Mobian (FDE, bookworm)
I cannot say, if there are other packages involved, but for me this powersupply update solved the problem.
Maybe you can try to run the latest Mobian image on a SD card to check, if something is wrong with your hardware.
Cheers and good luck!
Edit: sunxi64 kernel 5.15, using an Anker PowerWave II Sense Stand 15W
Edit2: I'm back at 0.5A - and I have no clue, what happened! (there was an USB-related update today...)
Back at 1.5 A... The magic is still on.
EDIT: The magic might be disenchanted. Using the wireless charger to start the phone increases the charging power to the max. Removing the phone and re-placing it on the charger switches the amperage to 0.5... This behaviour is reproducible. But don't ask me why!
This could be a general charging issue or maybe it's related. I often have similar problems with the regular charging method where the phone only charges with 0.5 A (on Manjaro unstable). Replugging the cable doesn't help in these cases and neither does rebooting the phone with the charger plugged in. What always works to enable 1.5 A charging though is to shut down the phone and then start it up by plugging in the charger.
  keyboard case charging but not typing new2pinephone 19 28,051 02-14-2025, 04:09 PM
Last Post: zltpxqhp69o2
  Keyboard : replaced the logic board charging now working again grump_fiddle_reinstall 1 2,917 07-01-2023, 07:57 AM
  keyboard charging fault, chip "most likely damaged", how to be sure? korakin 1 3,553 10-06-2022, 02:50 AM
Last Post: korakin
  Charging stuck at 3700mV tmczar 2 3,960 06-08-2022, 04:12 AM
Last Post: SwordfishII
  Keyboard case not charging (or not working) and a possible FIX for both pifou 12 20,560 05-03-2022, 03:09 AM
Last Post: wibble
  KB: Phone not/barely charging from power supplies when keyboard is not full Phalio 12 20,480 04-16-2022, 01:11 PM
Last Post: Phalio
  Keyboard stopped charging Shatur 7 10,328 03-30-2022, 07:26 PM
Last Post: enQueued
  PP Keybboard Charging Improvement drh 0 5,196 03-15-2022, 05:32 AM
Last Post: drh
  Convergence dock not charging pinephone mobian tecnocris 8 15,771 09-11-2021, 06:43 PM
Last Post: bcnaz
  Best charging adapter Regula 1 4,859 03-14-2021, 03:22 PM
Last Post: Regula
