Possible 2 Pin Fans
Question
I wonder myself which fans are compatible to the fan header. Since it is a 2 pin PWM header normal (3 to 4 pin) fans should not work, right? Would it be possible to use a 2 wire 12V DC fan and just replace the connector?
Thanks in advance!
best regards
(01-29-2022, 04:35 AM)Simlog Wrote: Hello,
Thanks in advance!
best regards
Should be possible
