Kodi xbmc
right folks
can someone help I'm trying to get kodi onto my pine a64 where do I start. I'm at the beginning
(05-25-2016, 05:19 PM)Myrealnameis Wrote: right folks
Burn the Android build to microSD card, and use Google Play store to install Kodi app.
(05-25-2016, 05:21 PM)Thank you kindly  I will try that.  Would you have a link to the android build incase i cannot find it?Again thank you Wrote:
Hi
Can find all the images here. Make sure to download phoenix card (remember to set 'startup!' when burning the image) to burn the phoenix card image // OR  win32imager to burn dd images (make sure you have the correct size for your sd card).
You can also just get the TV64 image by tohipfortheroom (a dd image) - Im pretty sure it comes with kodi installed.
Hope this helps
[edit] if you encounter problems join the chat (see my sig) and ask for help; if no one responds type !android in the chat box -- a bot will walk you though the steps
  Kodi Iona 18 66,952 01-29-2017, 08:51 PM
Last Post: Bluphire
  kodi on ubuntu? gychang49 5 12,783 10-09-2016, 08:52 PM
Last Post: gychang49
  kodi install on A64, 2GB gychang49 1 7,065 10-02-2016, 07:32 AM
Last Post: MarkHaysHarris777
  kodi xbmc for pine mbjpine64 4 10,291 05-22-2016, 02:45 AM
Last Post: mbjpine64
  Pine + KODI jamesnl 1 8,916 02-12-2016, 04:55 AM
Last Post: Ghost
