Gnome podcasts
Will it be soon possible to install gnome-podcasts on mobian as a .deb package? I don't like using flatpaks.
I learned I had 2 Flatpaks installed after realizing that my eMMC was almost full, the Flatpak folder alone singlehandedly filled up the entire storage with basically garbage data.
Those were the only 2 I installed from "Software Center" rather than apt, so I agree when you say you don't like using Flatpaks.
As for gnome-podcasts, you can alternatively install Git, Meson, Gstreamer, Rust, and Cargo, and then do the following:
git clone https://gitlab.gnome.org/World/podcasts.git gp cd gp meson --prefix=/usr build ninja -C build sudo ninja -C build install
母語は日本語ですが、英語も喋れます(ry
(11-07-2021, 09:26 PM)ryo Wrote: I learned I had 2 Flatpaks installed after realizing that my eMMC was almost full, the Flatpak folder alone singlehandedly filled up the entire storage with basically garbage data.
Thanks for the help, but after the command :
I get "command not found", what am I doing wrong? I installed git and meson before
Did you install Meson through Pip or Apt?
Other than for making a some modifications in Phosh, I never really used Meson myself, so I can't really assist on that one.
Through apt, np thanks anyway for the intention to help. "arigato"
  New camera app gnome-snapshot working on trixie? vusra 4 5,106 04-11-2025, 02:53 AM
Last Post: vusra
  gnome-control-center: segmentation fault on startup jojuma 4 6,100 09-12-2023, 08:49 AM
Last Post: jojuma
  Dist-upgrade and Chatty vs Gnome-Contacts biketool 9 12,032 09-30-2022, 08:53 PM
Last Post: treebeard
  Gnome Web CSS problem? jojuma 0 2,162 05-27-2022, 11:43 AM
Last Post: jojuma
  Change GUI from Phost to Gnome (or anything else) johnpine 0 2,304 05-27-2022, 06:52 AM
Last Post: johnpine
  Gnome-podcasts on Debian repos user641 4 7,444 02-06-2022, 04:58 AM
Last Post: jsch
  Gnome podcasts user641 0 2,283 01-03-2022, 06:56 PM
Last Post: user641
  *urgent help*calls and gnome-conatcs gone after update user641 24 37,147 09-20-2021, 12:19 PM
Last Post: calinb
  gnome podcasts on debian repo, dino-mobile user641 3 7,018 09-11-2021, 12:04 AM
Last Post: user641
  (Gnome) Maps won't start on Mobian? TRS-80 3 6,458 07-11-2021, 12:09 PM
Last Post: TRS-80
