Article: Internal Temperature Sensor on BL602
Here's how we read the Internal Temperature Sensor on PineCone BL602 and PineDio Stack BL604... And transmit to The Things Network via LoRaWAN
(10-14-2021, 12:55 AM)lupyuen Wrote: Here's how we read the Internal Temperature Sensor on PineCone BL602 and PineDio Stack BL604... And transmit to The Things Network via LoRaWAN
I am kind of surprise that BL602 has an internal temperature sensor. Can this sensor been use as ambient temperature measurement?
(10-14-2021, 07:51 PM)tllim Wrote: I am kind of surprise that BL602 has an internal temperature sensor. Can this sensor been use as ambient temperature measurement?
I don't think the Internal Temperature Sensor can be used for measuring the Ambient Temperature... My readings range between 45 ºC and 50 ºC, something in the BL602 SoC seems to be heating up. (Maybe WiFi?)
Or perhaps I'm not reading the Internal Temperature Sensor correctly.  ?
The value seems reasonable to me.
If this helps: Here is the Internal Temperature I recorded with PineDio Stack shortly after rebooting.
BL604 is mostly idling, and every 60 seconds it sends the temperature over LoRaWAN to The Things Network...
For quite a few sensors (or at least those of my interest), the system temperature helps calibrate the sensor readings. Load cells need this kind of calibration for weight. If the system is very enclosed, the internal temperature could work... It may also correlate sufficiently with the overall system temperature for the calibration lookups.
But in that application, one of the 8051+eeprom+BLE systems works fine.
Cool! That's an interesting application of the Internal Temperature Sensor.
FYI: I have recorded the Internal Temperature over a 20-minute period, here's how it looks...[Image: 811a4407f25ba02bf3010a1f826ee67f.jpg]
  Article: The Advantages of mobile Linux over AOSP amosbatto 2 471 10-20-2026, 02:38 PM
Last Post: zetabeta
  Article: Will Linux phones become a viable alternative to the Android/iOS duopoly? amosbatto 11 1,587 10-19-2026, 09:52 AM
Last Post: amosbatto
  [article] Linux Phone Takeover Juergen 4 7,017 10-08-2025, 02:31 PM
Last Post: zech.dexos
  [Article] RISC-V Ox64 BL808: UART Interrupt and Platform-Level Interrupt Controller lupyuen 2 12,888 09-03-2025, 10:51 PM
Last Post: PrinceMorissette
  [Article] Creating the Unicorn Emulator for Avaota-A1 SBC (Apache NuttX RTOS) lupyuen 0 3,739 04-12-2025, 06:04 PM
Last Post: lupyuen
  [Article] Porting Apache NuttX RTOS to Avaota-A1 SBC (Allwinner A527 SoC) lupyuen 2 5,020 03-22-2025, 07:30 PM
Last Post: lupyuen
  [Article] StarPro64 EIC7700X RISC-V SBC: Maybe LLM on NPU on NuttX? lupyuen 2 5,659 03-08-2025, 09:20 PM
  [Article] Test Bot for NuttX Pull Requests ... Tested on Real Hardware (Oz64 SG2000) lupyuen 0 3,425 02-15-2025, 11:26 AM
Last Post: lupyuen
  [Article] RISC-V Emulator for Pine64 Oz64 SBC lupyuen 2 4,957 07-07-2024, 04:19 AM
Last Post: lupyuen
  [Article] Rust Apps on Ox64 BL808 RISC-V SBC and Apache NuttX RTOS lupyuen 2 4,732 07-06-2024, 06:51 PM
Last Post: lupyuen
