PhoenixCard Burning Error
Hello! I've encountered same problem..
And the solution (that work for me) is compatibility mode with Win 7
(04-21-2016, 07:23 PM)alin123 Wrote: I did all the instructions on the wiki to select the image file, format to normal and then burn. Although, part way through the burn it says error and stops. I have tried it multiple times
Buy a name brand card from a trusted retailer. Your issue is a low quality card.
Backer number: 24,762
Backerkit STATUS: Items Received
  Need Sollution : Screen Problem and says the Error "Out of Range" on the display hunterzonecss 2 6,914 04-19-2019, 08:26 AM
Last Post: psychedup
