Case hardware request/idea
Some of us live in remote and or mountainous areas with poor to no signal strength for 2g,3g,4g and gps Im wondering if a case could be made that has an extra battery/batteries and external antenna ports for powered higher strength antennas. Im also wondering if the 6 gold breakout pins in the back would be sufficient for such a modular case.
The six pins on the back can be used for an extra battery - and will be in the keyboard case which is hoped to be in the store later this month. The 2g/3g/4g antenna is already using a coax connector (UFL I think) so changing to a better antenna should be easy. The GPS antenna is trickier but I think there have been a couple of attempts, one soldering a coax cable to the board in place of the sprung contacts, and another enlarging the existing printed antenna with some aluminium tape.
(09-12-2021, 03:59 AM)wibble Wrote: The six pins on the back can be used for an extra battery - and will be in the keyboard case which is hoped to be in the store later this month. The 2g/3g/4g antenna is already using a coax connector (UFL I think) so changing to a better antenna should be easy. The GPS antenna is trickier but I think there have been a couple of attempts, one soldering a coax cable to the board in place of the sprung contacts, and another enlarging the existing printed antenna with some aluminium tape.
Im assuming that keyboard is detected as a usb rather than serial device is this the case? If so any usb capable gps or lte antenna could be incorperated and utilize the break out pins then.
i2c is the only data connection available on the pogo pins. The keyboard is an i2c device.
You could connect a USB device using the usb dock. https://pine64.com/product/pinephone-usb-c-docking-bar/
No - see https://wiki.pine64.org/wiki/PinePhone#Pogo_pins - it's only power and i2c on those pins. Even if it did have USB you can't attach an antenna that way. It would have to go to one of the antenna connections that I mentioned on the main PCB. The sprung antenna contacts connect to the printed antennae near the top corners of the inner frame - they aren't the same as the 6 pogo pins.
There are band transponder boosters, pretty much applies a LNA across a whole bandpassed cellular band(think like the LNB you receive with in your satellite dish) and output a weak amplified signal in your house. You could try to make one or they are about $100 and work pretty well though sometimes a nearby cell will freak over the received signal fake 'echo' it makes. Works better with a good on-band dish or yaggi antenna pointed at the tower on the receive side.
  Battery Life- hardware abstraction layer-GPU VS optomizing app for GPU-openGL biketool 1 4,003 09-20-2024, 04:04 AM
  Microphone on Hardware Model 1.2 is Unusably Noisy In Some Circomstances ASmartSuitedSimpleton 4 10,655 03-23-2024, 10:55 AM
Last Post: Ferriah
  Is the hardware still being developed and refined? orbital 10 14,639 09-01-2022, 08:05 PM
Last Post: orbital
  How to check hardware revision? jojuma 1 4,961 07-16-2022, 12:28 AM
Last Post: bokomaru
  Modem Hardware bad? Not ready for 5g?? linux76 8 11,717 05-31-2022, 06:41 PM
Last Post: SwordfishII
  adding some keys to pp keyboard case, pageup, pagedown, f11, f12, maybe others zetabeta 1 3,509 04-30-2022, 08:18 PM
Last Post: TRS-80
  Any experiences with hardware mod to improve eMMC speeds? kqlnut 9 14,249 04-19-2022, 02:36 PM
Last Post: kk22
  Hardware switch for mic is not working properly submariner 10 17,379 01-25-2022, 07:01 AM
Last Post: wibble
  Request for Files regarding new cases [REDACTED] 0 2,347 01-02-2022, 01:42 AM
Last Post: [REDACTED]
Bug [Support Request] Modem is Failing to Be Accessible FriendlyGecko 3 6,970 11-30-2021, 01:22 PM
Last Post: FriendlyGecko
