Retropie on Pinephone
I borked my system and now the pinephone only boots to a blank screen. So I'll take this opportunity to reinstall retropie and record my steps as I go.
Edit: Moved the installation instructions into post #3
Notes: Emulationstation will launch games on a fresh install but fiddling with retroarch config settings seems to break it. The xmb menu driver for retroarch frontend was previously fast but unresponsive after reinstall. I was unable to get to the bottom of it so change the menu driver to rgui to avoid the headache. Select the terminal keyboard on squeekboard and the default keys for navigating the menu are capital W and X for left/right, F4 for enter, capital Z for down and the up arrow key for Up. Capital P and O are select/back keys. Disable audio-sync and video vsync settings for best emulation performance. Enable sync to content frame-rate to deal with overspeed. Select tinyalsa for audio driver to minimise stutter.
Extra: The xmb menu lag was caused by installing assets, ie the menu icons. Looks like you can disable shadows, smoothing, etc but simplest option is to uninstall the assets. Go to the configuration tool in the retropie script menu and uninstall them from there.
does retroarch has a mobile UI with on screen controls??? i Know in android it has but i dont know if that is a separated android implementation only....
(05-06-2020, 05:50 AM)paju1986 Wrote: does retroarch has a mobile UI with on screen controls?
I'm not a fan of touchscreen controls but should be possible according to this link - I haven't got retroarch installed currently so unable to test.
Edit: The joypad overlay shows up but probably need to remap the keys to make it work.
.jpg   retroarch-virtualpad.jpg (Size: 62.36 KB / Downloads: 401)
  Using Signal on PinePhone in mid-2023? dante404 47 14,697 05-03-2024, 02:19 AM
Last Post: dragonhospital
  Slarm64 on PinePhone [Unofficial Slackware ARM - 64 bit] acid andy 38 25,827 04-23-2024, 10:29 AM
Last Post: donchurch
  PinePhone app development WhiteHexagon 15 4,360 04-23-2024, 05:19 AM
Last Post: Jonnyc
Wink PINEPHONE not booting Touchwood 2 573 02-23-2024, 07:27 AM
Last Post: Touchwood
  Slack on PinePhone Adam Seline 5 5,565 12-20-2023, 07:20 AM
Last Post: nickolas
  Struggle to install LibreOffice on the PinePhone Peter Gamma 48 25,190 11-24-2023, 07:02 AM
Last Post: Peter Gamma
  Which word processor to choose for the Pinephone? Peter Gamma 8 2,244 11-23-2023, 01:06 AM
  openSUSE for Pinephone Alefnode 75 103,670 11-17-2023, 08:37 AM
Last Post: Uturn
  Genode- Sculpt OS for the PinePhone (non Linux) Surehand53 1 1,097 11-04-2023, 07:23 PM
  Abiword as a office mobile word processor for the Pinephone? Peter Gamma 11 2,567 10-24-2023, 08:57 AM
