My PinePhone won't start. I am giving it away if you want to try and fix
Big Grin
I got my PinePhone a few weeks ago. It worked great for a few hours. I tried changing the OS and all of a sudden, it won't start. I tried doing some of things people mentioned in the forum but it didn't work for me. Now it's just sitting on my desk.
If you want to try to fix and play with it, let me know. I can ship it to you, for only shipping. PM/DM me. Thanks/MS
(03-02-2020, 11:58 AM)mswaleh Wrote: Hi,
Ill take it off you, I tried to send you a PM , but seems like your Private Messages are disabled ?
PM me when you get a chance pls.
Connect to it via serial console. Any USB to 3.3V TTL converter that uses RS-232 for serial communication transmission and adapts to a 3.5mm audio jack will do. From there you should be able to see what the issue is. For an idea on how to connect your computer to a serial console see me post about my experience connecting with a serial console: https://forum.pine64.org/showthread.php?tid=9516.
Post back and let us know what you find out after attempting to boot while connected to the serial console.
Also, remember that the PinePhone will boot both from eMMC and SD. Don't give up so easily, I am sure you can revive your PinePhone.
Cheers!
dustfinger
  Pinephone won't boot. spha 13 3,039 5 hours ago
Last Post: Richy_T
  Pinephone boot. Richy_T 5 233 11 hours ago
Last Post: Richy_T
  eSIM on PinePhone just_a_q 4 2,764 05-14-2024, 01:35 PM
  PinePhone - boot from microSD laserpyramid 9 967 05-03-2024, 10:09 AM
Last Post: laserpyramid
  pinephone virtual keyboard aular 4 479 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 326 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 111,727 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 2,000 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 713 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,672 12-28-2023, 07:55 AM
Last Post: MTXP
