gigabit autonegotiate
Slightly different gigabit issue, I have the 2gb A64+ and the ethernet connection always connects at 100,  even though the switch is a gb one and will auto negotiate, any suggestions?
Thanks,
Drew
POE. I see your other thread. Try a Cat 5e or better cable without your POE setup. See if that works. Also post what switch you are using we may as well start trying to correlate issues with specific hardware.
(05-04-2016, 10:27 AM)rahlquist Wrote: POE. I see your other thread. Try a Cat 5e or better cable without your POE setup. See if that works. Also post what switch you are using we may as well start trying to correlate issues with specific hardware.
I believe you are correct about the cable, I will try that after I take it home, I have it at work now and minus the poe splitter it does detect GB speed.  At home I was not using the splitter, but the cable could be suspect.
Thanks,
Drew
  Pine A64+ Gigabit issue... rhkean 34 45,614 07-17-2016, 07:32 AM
Last Post: niall
