Disable Auto Power On Rock64
Hi
I have a Rock64 with OMV 4 installed and it works pretty well. My router and network switch are programmed to power off completely every night so I want to schedule an automatic shutdown on OMV itself and I know this can be easily done with cron jobs. However, when my router does power on I don't want the Rock64 to power on as soon as power is detected and instead use wake-on-LAN to boot it at a specific time.
Is it possible to disable the automatic power on and does the Rock64 support wake-on-LAN?
Many thanks
Will
Can anyone help?
Wish I could help, but you may have luck jumping into the #rock64 IRC room and asking there.
Cheers for the reply. I'll give the IRC a go.
I wonder would some form of inline switch, timer based between your power supply and your board be a solution. Did you look at anything that might involve the GPIO pins.
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 293 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 8,375 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 5,708 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 4,172 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 338 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 1,903 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 3,542 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 2,118 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 765 11-28-2022, 02:18 PM
Last Post: Macgyver
  my rock64 dosen't work rookie_267 0 963 10-07-2022, 07:50 PM
Last Post: rookie_267
