Issue with Widgets on Android
Most widgets, when I try to place them on my home screens hang and fail.  I found this in the log (similar messages for lots of widgets):
This is consistent whenever a widget has a "configuration" screen after placing it.  Widgets without a configuration screen seem to work OK. One example widget is the MSN Money app, when you try to add the stock widget after selecting the stock symbol it crashes.
05-03 15:20:07.758: E/AndroidRuntime(18457): Process: com.android.launcher3, PID: 18457
05-03 15:20:07.758: E/AndroidRuntime(18457): java.lang.NullPointerException: Attempt to invoke virtual method 'boolean com.android.launcher3.CellLayout.findCellForSpan(int[], int, int)' on a null object reference
05-03 15:20:07.758: E/AndroidRuntime(18457):     at com.android.launcher3.Launcher.completeAddAppWidget(Launcher.java:1623)
05-03 15:20:07.758: E/AndroidRuntime(18457):     at com.android.launcher3.Launcher.completeAdd(Launcher.java:727)
05-03 15:20:07.758: E/AndroidRuntime(18457):     at com.android.launcher3.Launcher.finishBindingItems(Launcher.java:4516)
05-03 15:20:07.758: E/AndroidRuntime(18457):     at com.android.launcher3.LauncherModel$LoaderTask$10.run(LauncherModel.java:2764)
05-03 15:20:07.758: E/AndroidRuntime(18457):     at com.android.launcher3.DeferredHandler$Impl.handleMessage(DeferredHandler.java:51)
05-03 15:20:07.758: E/AndroidRuntime(18457):     at android.os.Handler.dispatchMessage(Handler.java:102)
05-03 15:20:07.758: E/AndroidRuntime(18457):     at android.os.Looper.loop(Looper.java:135)
05-03 15:20:07.758: E/AndroidRuntime(18457):     at android.app.ActivityThread.main(ActivityThread.java:5254)
05-03 15:20:07.758: E/AndroidRuntime(18457):     at java.lang.reflect.Method.invoke(Native Method)
05-03 15:20:07.758: E/AndroidRuntime(18457):     at java.lang.reflect.Method.invoke(Method.java:372)
05-03 15:20:07.758: E/AndroidRuntime(18457):     at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:920)
05-03 15:20:07.758: E/AndroidRuntime(18457):     at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:715)
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 391,982 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 30,032 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 17,014 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 7,050 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 7,121 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 5,662 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 3,372 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 261,341 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 3,580 02-26-2019, 11:58 AM
Last Post: Twistedx
  Android 7.1 (PINE A64(+)) pineadmin 59 106,143 02-10-2019, 07:44 PM
Last Post: mmmarcus
