Kill switches
Is it safe to switch the kill switches on / off with the phone on?
Or should I shut down, then flip the switch. I stuck my battery in with some double sided tape, Im reasonably confident it wont detach while removing the cover.
I always remove the battery.
To change the memory card many times a day.
It never felt down while removing the cover.
Electrically it looks like it should be ok. Software wise I don't know - it may cause confusion.
  USB-C CC pins are pulled to the GND by AW3512 (VCONN switches) when VCONN is off fsflover 41 51,269 06-17-2021, 04:54 PM
Last Post: feklee
  Is the PinePhone only Pine-device with hardware switches? harrm 1 2,223 01-23-2021, 12:29 AM
  Where are the HW kill switches located? WaldoTheRanger 11 14,469 10-04-2020, 02:23 AM
Last Post: WaldoTheRanger
  Only enable modem when needed with kill switches sokolgeo 2 4,094 09-20-2020, 04:40 AM
Last Post: sokolgeo
  hardware switch wishlist/discussion - switches on the outside? mypine 7 7,421 04-12-2020, 10:40 AM
Last Post: wibble
