How to turn Bluetooth radio off by default
Hello I was wondering how the Bluetooth radio can be configured so it is off by default every time the system starts up? Thanks.
Are you looking to prevent Bluetooth access on boot?
Or reducing power usage?
The Bluetooth part of the WiFi chip uses a separate interface from WiFI. That can be software disabled to prevent access. However, you would need to send the Bluetooth chip a command to disable the radio.
Whence it's figured out, (both radio off and disabling access), we need it on the Wiki.
Arwen Evenstar
Princess of Rivendale
I think the command is something like:
rfkill block bluetooth
would have to put it in some startup script.
EDIT:
For systemd it's actually really easy, just enable the rfkill-block service:
Cool Thanks. Still fairly new to linux, so some features I just sort of expect in a distro, especially when it comes to radio connectivity stuff by default.
If it can be set to off by default, after clicking the bluetooth icon, it would make sense since this would save some power, eliminate unwanted connections or automatic pairing that is undesired, reduce EMF (yes I am sensitive to it), and so on.
Thanks for the help.
(02-05-2020, 09:42 AM)slyecho Wrote: EDIT:
This doesn't seem to work on Manjaro.
Well, I tried and yes, it seems to be activated on boot. If you deactivate the bluetooth service:
sudo systemctl disable bluetooth
Then it seems to stay off, however you need to start the service manually then, too.
I, myself just keep it on all the time, I haven't really needed to squeeze the most from the battery because it is already very impressive on its own.
The problem on Manjaro is that Blueman turns the radio on by default.
Here is how you disable this behavior:
right click on the bluetooth panel icon > select 'plugins' > PowerManager > configuration > unselect the auto power on option
Should work on any distro that uses blueman and turns radio on by default.
  Nethunter default password failed lamlarryyyy 0 352 11-23-2023, 02:48 AM
Last Post: lamlarryyyy
  Big bluetooth problems ColoBill 2 1,151 12-15-2022, 01:38 PM
Last Post: ColoBill
  when i close my laptop lid the screen doesn't turn on? (debian bullseye based) computerc 3 1,906 09-23-2022, 08:37 PM
Last Post: computerc
  Enabling spekaer/Connecting to bluetooth from command line axisarm 1 1,949 08-06-2021, 04:29 PM
Last Post: nfms
Music No sound on PBP default installation ivek 9 9,312 05-09-2021, 05:58 PM
Last Post: binholz
  curious why KDE by default? dieselnutjob 7 7,711 07-18-2020, 03:21 PM
Last Post: Damon
  Root access over SSH enabled by default gibby 3 6,313 06-28-2020, 01:19 PM
Last Post: Arwen
  Better (than default Debian/MATE) Linux distro? mspohr 34 36,119 06-11-2020, 01:34 PM
Last Post: s3rvant
  Slow WiFi on Manjaro Default Image 20.04 for PBP SuperUJ 8 9,499 05-28-2020, 08:16 PM
Last Post: nekojet
  Default Manjaro KDE build download link for Pinebook Pro? qeek 8 8,743 03-21-2020, 09:41 AM
Last Post: MrDitchy
