Which sound preference for "hardware" and "speaker"
I lose audio output whenever I reboot my PBP. I've gone through sound preferences, hardware, speaker options,  tried different profiles and tested them. Currently "stereo output and stereo input" puts sound out. If I reboot, I no longer have sound even with the same profile I selected earlier. I have to go back to sound preferences and try other profiles. How can I get sound on the PBP consistently without changing the profile?
Bionic Ubuntu + Mate
(11-19-2019, 10:37 AM)richfm Wrote: I lose audio output whenever I reboot my PBP. I've gone through sound preferences, hardware, speaker options,  tried different profiles and tested them. Currently "stereo output and stereo input" puts sound out. If I reboot, I no longer have sound even with the same profile I selected earlier. I have to go back to sound preferences and try other profiles. How can I get sound on the PBP consistently without changing the profile?
My audio used to work fine, 'phones or internal speakers. Now not a peep. Undecided I have also tried multiple settings combo, but i have yet to find one that works. I can't put my finger on anything that might have caused it. (default debian/mate with all updates)
  New Hardware names_mark_ 1 146 04-23-2024, 08:41 AM
Last Post: dachalife
  Hardware makes a strange pop noise. Gemeindepirat 7 2,954 08-12-2023, 01:59 AM
Last Post: User 27258
  Pinebook Pro malfunctioned hardware samtux 10 4,417 12-27-2022, 03:31 PM
Last Post: samtux
  PineBook Pro revision 2.2: Wishlist for the hardware issue fixes dsimic 115 136,058 11-30-2022, 04:28 PM
  PBP (PPP) docking deck : no hdmi sound Rosbeefandino 0 984 07-24-2022, 06:19 PM
Last Post: Rosbeefandino
  Hardware shortcomings commiecam 14 9,067 01-30-2022, 09:04 AM
Last Post: moonwalkers
  Pinebook pro Hardware failure: how should I diagnose it? alxndr.psclt 5 4,699 09-08-2021, 09:03 PM
  Fix your Pinebook Pro speaker connection KC9UDX 12 11,142 07-08-2021, 02:10 AM
  Inverted speaker stereo polarity slyecho 12 14,796 09-22-2020, 12:08 AM
Last Post: Artcfox
  hardware compatibility table in the wiki.. kernel version? speculatrix 1 3,189 09-09-2020, 08:06 AM
