Which application can I use to test webcam?
Camera works great in manjaro. I’ve tested with cheese. Didn’t count frame rate, but visually it was per decent.
It can also be tested with mpv with different settings. Although I think we all have same cameras it's worth to take a look at what it offers:
v4l2-ctl --list-formats-ext -d /dev/video3
ioctl: VIDIOC_ENUM_FMT
       Type: Video Capture
       [0]: 'YUYV' (YUYV 4:2:2)
                       Interval: Discrete 0.100s (10.000 fps)
                       Interval: Discrete 0.200s (5.000 fps)
               Size: Discrete 1600x1200
                       Interval: Discrete 0.050s (20.000 fps)
                       Interval: Discrete 0.067s (15.000 fps)
And then experiment with some settings. It's actually not that bad unless you are David Attenborough Smile
For me - the best results are with following settings (--profile=low-latency is important).
mpv --demuxer-lavf-o=video_size=640x480:famerate=20 av://v4l2:/dev/video3 --profile=low-latency
  What are the actual supported framerate/resolution pairs for the PBP webcam? gleachkr 2 3,825 09-19-2020, 10:23 AM
Last Post: xmixahlx
  Stress Test (kernel compile) hmuller 8 12,105 07-04-2020, 04:15 AM
Last Post: nobodyinperson
