USB-C dock
So far I haven't had much luck with the Anker PowerExpand+ 7-in-1
https://smile.amazon.com/gp/product/B07PPGWQ15
My results have been similar to @jabo .
Power pass through works.
Doesn't work:
HDMI video out.
USB accessories (keyboard and mouse)
SD reader
Ethernet
EDIT: Using stock Debian/Mate image
Works with Ubuntu image! https://forum.pine64.org/showthread.php?...7#pid51887
(11-02-2019, 12:46 PM)embhorn Wrote: So far I haven't had much luck with the Anker PowerExpand+ 7-in-1
Doesn't work:
HDMI video out.
SD reader
Ethernet
Microsoft Display Doc just charges. No video, no USB-hub. Pinebook screen flashes, so there is something detected...
(10-06-2019, 12:22 PM)jabo Wrote:
(10-06-2019, 11:46 AM)Meatball Wrote: I'm still waiting for my pbp but I'm in batch 1.
When I get mine I'll check compatability with my dock (https://www.deltaco.eu/en/products/n%C3%.../USBC-1266)
After looking at the dock you linked and at the wiki page for the pbp it looks like it should work as the pinebook pro uses Alt DP
Video
USB-C Alt model DP up to 3840x2160p60
Sent from my PH-1 using Tapatalk
So far I have only tested the USB, charging and hdmi and charging + hdmi out works fine! USB not so much.. Have alot to do and not much time but will update when I test the SD card reader and ethernet!
I have the bionic ubuntu image installed though so can't vouch for functionality on the default Debian image!
Linux newbie learning programming as a hobby!
Pinebook Pro running bionic ubuntu
Rockpro64 4gb v2.1 in the NAS enclosure running omv
Rock64 1gb as a retrogaming station
I bought this one
USB C HUB Adapter,QGeeM 4 in 1 USB C to HDMI Adapter with 4K USB-C to USB 3.0,Type C to USB 2.0, 100W PD Charger Compatible with MacBook Pro 2019/2018 IPad Pro,Chromebook,XPS,USB C to USB https://www.amazon.com/dp/B07Y6F74F1/ref...WDbY7S0TQY
HDMI doesn't work.
Sending it back
(11-05-2019, 07:37 PM)mspohr Wrote: I bought this one
HDMI doesn't work.
Sending it back
If I understand USB C DisplayPort alternate mode, you would need a device that uses DisplayPort on the USB C side. Or video drivers for a USB video device.
My goal is USB C charging, USB 3 hub with at least 2 ports, and DisplayPort alternate mode. Bonus if I get Gigabit Ethernet. Not sure if that's possible. But I will be looking.
In the short term I will live with a simple USB C DisplayPort alternate adapter cable. Then use the barrel charger.
Arwen Evenstar
Princess of Rivendale
Doesn't work:
HDMI video out.
SD reader
Ethernet
I tested with the Ubuntu-Mate image (using @Wizzard 's excellent tutorial)
Everything on the dock is working! This is fantastic!
EDIT:
Upon closer inspection, everything is working except ethernet, as discussed later in this thread.
Doesn't work:
HDMI video out.
SD reader
Ethernet
Is it safe to assume your quoted, failed attempt was using the default Debian?
Doesn't work:
HDMI video out.
SD reader
Ethernet
Correct. I'll edit the originals to clarify.
#19
HDMI doesn't work.
Sending it back
Any advice on a specific device that supports Display port alternate mode?
#20
Doesn't work:
HDMI video out.
SD reader
Ethernet
The same for me with a different brand. Working after switching to Ubuntu/Mate
  Pine Dock Networking Issue trillobite 1 300 02-10-2024, 12:03 AM
Last Post: trillobite
  Pinebook Pro Dock - cannot connect to monitor Dominik 4 3,512 06-12-2022, 10:53 AM
Last Post: Rosbeefandino
  Getting the dock to work. wove 2 4,153 12-27-2020, 09:27 AM
Last Post: wove
  Pinebook Pro Dock Power Requirements calinb 9 12,295 12-16-2020, 09:24 AM
Last Post: dsimic
  Pinephone dock with Pinebook Pro? karlnicholas 2 4,918 09-21-2020, 05:11 PM
Last Post: karlnicholas
  USB-C hub/dock/video Corkonian 2 4,803 11-02-2019, 02:29 PM
Last Post: Corkonian
