Please update PineH64 pages to say Armbian is unsupported
I feel really silly posting this, but the Armbian folks were pretty direct about Armbian support.
The net result is that ANY H64 board is apparently so unsupported, that asking questions about it is wasting their time and abusive (their words, and sorry for being snarky/not sorry).
The wiki page:
https://wiki.pine64.org/index.php/PINE_H64_Main_Page
Does not state any of that.
I would suggest updating it to say "Unsupported" per Igor, below:
Quote:Igor:
I does not matter. There is no support for Pine H6. Not for A and not for B. Support = dealing with users. There are only testing images for whatever is on that name/picture. If you have problems with those images, your messages usually goes to /dev/null It was a miracle that it came this far. Closing again.
Emphasis mine.
Note that the same page on the Armbian site doesn't specify "A" or "B", just shows a picture. Apparently, you're supposed to compare the picture and then realize you have a different board; despite the fact that the H64 page on Pine64 for the "B" board links to the same build. Per Tido/Retro:
Quote:Tido:
As long as you have no problems with your eyes, simply look - does any of these boards look like yours :
https://www.armbian.com/download/?tx_maker=pine64
I answer for you: no. Yours is a totally different form factor with different HW. And with your expericence (as it states on your profile) you should least be able to guess it matters.
Dodgy
If you go to Pine64, the "B" board, then link to Armbian, there are no pictures, and no mention that only "A" works and neither is supported. The file name is missing an "A" but given that the Pine64 "B" page links here ... you would think it works.
So, maybe not so stupid.
In any event, the Raspberry Pi 4 is looking better and better ...
It's a shame, the power connector on the Pi4 is absurd; the H64 had a much better construction IMHO, more suited to a commercial, low quantity operation.
        == John ==
(07-11-2019, 03:23 PM)JGwinner Wrote: The wiki page:
I've put a comment on the wiki and linked back to your post about only the A board being a WIP.
I couldn't figure out how to make the text larger without making it a header.
If you think this should be altered further, you should be able to login to the wiki with your forum credentials...
Thanks Bunny.
Perfect!
Although it makes me sad Sad
I really want a version of Debian to work with this board. I'm going to keep working at it, but I can't make it a priority anymore, I have some production targets we have to hit.
== John ==
Armbian is still marked as unsupported, but they now have images for Buster Server, Buster Desktop and Disco Server all running Kernel 5.3 (images released 2019-11-19). I tried both Buster flavours and they work fine from SD-Card however they still won't boot from eMMC, the desktop is usable and has everything like the "normal" supported image for other boards.
(11-30-2019, 04:11 AM)as365n4 Wrote: Armbian is still marked as unsupported
It's a wiki and you can edit content using your forum credentials.  Smile
This is in reference to the Armbian website, they still have it marked as unsupported. ;-)
I get the feeling that the folks at Armbian don't like to interact with these pesky end-users of their work/images..... :-\
@ evilbunny
I have updated the wiki with the links to current downloads and pointer to the H64B page. ;-)
(07-02-2020, 04:10 AM)as365n4 Wrote: @ evilbunny
Thanks  Smile
  PineH64 Model B schematic martinayotte 1 6,267 03-06-2019, 04:16 PM
