Rock64 random freezes
Hello everyone,
This is my first post, so I'll spare a couple of lines to introduce myself:
I'm a hardware enthusiast, sometimes over my possibilities and capabilities, but that is the way I learn. I like running Linux in every device I have, sometimes just because. But I am far from being a Linux-only kind of guy: there is always room for Windows, OSX and FreeBSD.
I started to be interested in the Rock64 board a couple of months ago when someone introduced me to it. After reading on the forums for a while, I decided to buy it from someone that wasn't going to use it anymore. So far I've tried Debian Stretch and Armbian Ubuntu Bionic 64 images.
I am using it to host small headless server for internal use. The resources I am using are the built-in Ethernet, the CPU, the memory and the SD-Card.
To my surprise, I've been having random freezes with both images for a while. So I decided to debug the freezes by using an external UART to see if messages were dumped to the serial console. (I followed this instructions https://forum.pine64.org/showthread.php?tid=5029 )
These freezes could happen at random times, but mostly when I was interacting with the Rock64 through SSH protocol.
I tried to force this freezes with the stress command: sudo stress -c3 -m3; and succeded.
1-4 seconds after executing the stress command, the Rock64 board would freeze. I reproduced this four times in a row.
Would you think this is a board problem? I'm asking in case I have to ask for a refund from the person I bought the board from.
I'm pasting the kernel messages below for reference.
Salutations to everyone!
Random crash at boot:
https://pastebin.com/BtwZiqXc
First crash induced by stress:
https://pastebin.com/Dxp6SKvT
Second crash induced by stress + temperatures.
https://pastebin.com/5jK74aAP
Images used:
https://github.com/ayufan-rock64/linux-b...m64.img.xz
PSU:
Original 5v 3A.
Hi, which image (exactly which version) are you running? ayufan just released new stable
(07-01-2019, 05:12 AM)Luke Wrote: Hi, which image (exactly which version) are you running? ayufan just released new stable
Hi Luke,
When I captured the kernel errors above I was using bionic-minimal-rock64-0.7.8-1061-arm64.img.xz .
I may give revision 0.8.3 a go tonight to see if the freezes reproduce on that version.
Regards,
BTB
0.7.8 is very old at this point, so granted the nature of the issue is not related to hw then its likely fixed.
Hello, @BTB.
Did you have any luck finding the problem? I have the exact same issue with my board.
Yesterday I tried to reinstall the OS, and tested many distros. One thing I noticed is that it is complete random. At one point I used a clean Debian Minimal SD Card that I'd just created and it didn't pass the fist login.
I've had the v2 version of this board a few months and mines very picky about bootiing, compiling and nic stability. The v3 had a nic resistor fixed.
So you should say what board ver you have not just the image. I just installed ayufan's latest focal unstable img and it's working well for a day now.
ssh hangs were a problem on lots of diff distro's I tried. There's a command for turning off tcp offload out there which helps but escapes me atm. ethtool eth0 tx rx off blah.
By default Linux only runs the rk3328 at (approx!) 1.3ghz maximum cpu frequency
But Armbian may add a patch to boost that to 1.5ghz
This may cause problems maybe ? If you don't have a good power supply or the cpu gets too hot perhaps
You can try to change the max frequency:
sudo echo 1296000 > /sys/bus/cpu/devices/cpu0/cpufreq/scaling_max_freq
  Rock64 v2.0 u-boot SPI issues ju0n 0 291 07-05-2026, 11:02 AM
Last Post: ju0n
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 5,646 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 26,807 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 15,884 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 17,546 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 4,425 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 9,278 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 10,392 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 9,637 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 4,590 11-28-2022, 02:18 PM
Last Post: Macgyver
