Fan 12V
i saw this guy adding fans to his cluster board setup.
Since there seem to be 12V pins at J1 (http://files.pine64.org/doc/clusterboard...ematic.pdf) can i just add a PWM and a 12V fan?
Khaosgrille
(06-17-2019, 08:58 AM)khaosgrille Wrote: Hi,
Khaosgrille
Advise using 5V fan if hardware design is not your strong point. If you are hardware person, you can try the 12V wiring and careful, one small mistake can burn the clusterboard.
